POV-Ray : Newsgroups : povray.programming : Running POV-Ray Through DDE Link Server Time
2 Jun 2024 09:15:50 EDT (-0400)
  Running POV-Ray Through DDE Link (Message 1 to 7 of 7)
Subject: Running POV-Ray Through DDE Link
Date: 8 Oct 2009 14:05:01
Message: <web.4ace28dfe3f4e7b75d1de84f0@news.povray.org>
I have written a program that is DDE enabled. I'd like to send a command from
that program to POV-Ray (via DDE) and have POV-Ray load a file, render, and
create an image output (JPG,BMP,etc.). Is such DDE communication possible using
POV-Ray? Essentially, I'd like to run POV-Ray as a client from another program,
without having to launch it manually. Thanks in advance!
Subject: Re: Running POV-Ray Through DDE Link
Date: 8 Oct 2009 14:42:52
Message: <4ace32ac@news.povray.org>
You can invoke pvengine.exe with the /render and /exit switches to cause
POV-Ray to do something close to that. That may be sufficient.
Date: 8 Oct 2009 16:24:34
Message: <4ace4a82$1@news.povray.org>
... aside from that, there is no interface to drive POV-Ray
automatically, nor does POV-Ray's current license permit to distribute a
version that has such an interface added.
(Future versions are likely to be released under the GPL though, which
would then permit such a patch to be distributed I guess.)
Date: 8 Oct 2009 18:44:57
Message: <4ace6b69@news.povray.org>
GUI Extensions are enough for some interaction with another application.
Doesn't Moray use that, after all?
Date: 8 Oct 2009 19:31:26
Message: <4ace764e@news.povray.org>
While Moray may be using some plug-in mechanism to extend its own
(modelling) functionality (I'm no Moray expert, rather far from it
actually), when it comes to driving POV-Ray it must use the same method
as everyone else: Executing it with suitable command-line parameters.
Date: 8 Oct 2009 20:30:11
Message: <op.u1ibolqr7bxctx@e6600>
http://www.povray.org/documentation/view/3.6.1/699/
Moray used the GUI Extension interface to hook into POV-Ray, which allowed
it to start renders programmatically and capture render output in its own
buffers.
FE
Date: 29 May 2010 15:10:01
Message: <web.4c0165e33f4c95c6bba08f230@news.povray.org>
This is an old thread, so probably no one really cares any more and Fredrik
already pointed to the right area. But, since I just now read the message, I
thought I would throw out a suggestion or two for anyone in the future.
provides an example of a dynamic linked library that POV-Ray can access as a
GUI-Extension. Use this as a model to create a DLL. You will need to edit the
documentation. Read it carefully.) The program you are creating can also open
this same DLL and establish a DDE communications link.
I use DDE to poke a message into the DLL. The message has the rendering
information and the handle of my display window. You will see that the
the DLL post a windows message to my display window. The window reads the image
from disk and shows it.
It was a little tricky at first. But, it seems to work pretty well now. Good
luck.
TRP
www.imagicproductions.com the home of Alive! for POV-Ray
