POV-Ray : Newsgroups : povray.programming : Random and array Server Time
23 Mar 2026 03:17:43 EDT (-0400)
  Random and array (Message 1 to 7 of 7)
Subject: Random and array
Date: 22 May 2009 10:20:01
Message: <web.4a16b372ce522aaafb1f3ffe0@news.povray.org>
Hi :-),
I need help, I am making a stadium and I want to do people on it, I made it,
everything was good but, all of them had the same t-shirt, so I wanted to use
randomize function (this is my code):
#include "textures.inc"
#include "arrays.inc"
#declare lors = array[5] {Black,White,Red,Green,Blue}
#declare RS = seed(1215);
// camera ---------------------------------
camera {location <0.0 , 20 ,-34>
        look_at  <0.0 , 0.0 , 0.0>}
// sun ------------------------------------
light_source{<150,2500,150> color White}
// sky -----------------------------------
sky_sphere {
        gradient <0,1,0>
        color_map { [0.00 rgb <0.6,0.7,1.0>]
                    [0.35 rgb <0.0,0.1,0.8>]
                    [0.65 rgb <0.0,0.1,0.8>]
                    [1.00 rgb <0.6,0.7,1.0>]
                scale 2
            } // end of pigment
           } //end of skysphere -----------
// ground ---------------------------------
plane{ <0,0.0001,0>, 0
       texture{
          pigment {color White}
               } // end of texture
     } // end of plane
#declare kolorek = str((Rand_Array_Item(lors,RS))
#declare chopek = union{
difference {
  sphere { <0, 0, 0>, 0.2  scale <0,4,0>}
  box {<0,0,0>, <1,0,1> }
          pigment {color Red}
  sphere { <0, 0.7, 0>, 0.1  pigment {color Yellow} scale <0,1.3,0>}
   #local Index1 = 1;
#local Index3 = 0;
#while(Index1 <= 20)
   #local Index2 = 0;
   #while(Index2 <= 280)
      object {chopek translate <Index3, Index1*0.5, Index2*0.5> pigment { color
kolorek }
        #if (Index2= 20 | Index2=65 | Index2 = 110 | Index2 = 155 | Index2 = 200
| Index2 = 245)
          #local Index2 = Index2 + 5;
        #else
      #local Index2 = Index2 + 1;
   #local Index1 = Index1 + 1;
   #local Index3 = Index3 +1;
Any ideas, solutions to my problem? I have error  in the line:
--object {chopek translate <Index3, Index1*0.5, Index2*0.5> pigment { color
kolorek }--
I tried declared "kolorek" with object and brackets and without it but it still
does'nt work. Please help friends.
Subject: Re: Random and array
Date: 22 May 2009 13:45:00
Message: <web.4a16e4772809831692f9e9e10@news.povray.org>
Here, you declare "lors" as an array of colors...
.... here you seem to read out the array, and convert it to a string (why?? and
I'm rather surprised that you don't get an error here already)...
> kolorek }
.... while here again you want to have it interpreted as a color.
I guess it should work fine if you remove the "str()" from the declaration of
"kolorek"; actually, I think it should read:
#declare kolorek = Rand_Array_Item(lors,RS);
Date: 22 May 2009 13:55:00
Message: <web.4a16e6062809831692f9e9e10@news.povray.org>
I was a bit too quick with my answer; there's another flaw in your code, which
will result the t-shirt color to be random, but still the same for all people:
>    #local Index1 = 1;
> #local Index3 = 0;
>    #local Index2 = 0;
> kolorek }
You pick the "kolorek" value before the loop. However, I guess you want to pick
the value at random for each element in the loop; in order to do this, the
structure of your code should be:
#declare chopek = union {
  #while (...)
    object { chopek ... pigment { color kolorek } }
That is, you need to explicitly pick a new color for every iteration of the
loop.
Date: 23 May 2009 06:15:00
Message: <web.4a17cbe128098316fb19e9110@news.povray.org>
Thx a lot guys... I was thinking a lot about this, and with your ideas I find
solution :)  This is the working code:
#local Index1 = 1;
#local Index3 = 0;
difference {
                       } // end of union
#declare glowa = union {
              sphere { <0, 0.7, 0>, 0.1 scale <0,1.3,0> pigment {color Yellow}}}
   #local Index2 = 0;
      #declare kolorek = (Rand_Array_Item(lors,RS));
kolorek }}
      object {glowa translate <Index3, Index1*0.5, Index2*0.5>}
| Index2 = 245)
        #else
The declare of my chopek (man) and glowa (head) have to be declared before loop.
Str wasn't thing what I needed as you said.
And now as a dessert my work, people on the stadium on the bottom seats :-)
http://patryknowak.pl/stadion3.jpg
Once again thx for help :-)
Date: 23 May 2009 16:50:37
Message: <4a18619d@news.povray.org>
Looks very nice. However, you should add a small random element to
the position as well, it's a bit too regular for people. Also, making
the glowas a tiny bit larger and using color "Tan" instead of
"Yellow" could help, too.
Also note that your statements "scale <0,N,0>" actually mean
"scale <1,N,1>". Although POV can handle this for being able to
imply use "scale N*y", writing the 0 explicitely is misleading.
Date: 24 May 2009 01:12:58
Message: <4a18d759@news.povray.org>
> Hi :-),
> it, everything was good but, all of them had the same t-shirt, so I wanted
> to use randomize function (this is my code):
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code, not general questions of using POV-Ray.  Questions
about using POV-Ray should be asked/made in either povray.general or
povray.newusers.
Nicolás
(again, posting before Thorsten has to :D)
Date: 8 Jun 2009 11:40:00
Message: <web.4a2d3000280983163f1e88cf0@news.povray.org>
> > Hi :-),
> povray.newusers.
> Nicolás
I know it's wrong group, but I want to show final effect of my work.
Here is the link to youtube http://www.youtube.com/watch?v=K6puZu9MxY4 .
I'm beginner in using POv-ray so don't laugh :P
