![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think I've discovered a bug in the output of Targa files under windows XP.
I'm currently writing a small command line utility to work with .tga files
created in POV, and I've been trying to test some of the lower-level
functions by having it print out a list of files in a given directory and
show the type-code (2 or 10 for POV output) their bit-depth, and
resolution.
The documentation states that I can force POV to output targa files by using
the command line flag +Fxn, so I've been trying it with +FT8, +FT16, +FT24,
and +FT32, but no matter what depth I specify, POV always outputs a 24-bit
targa file.
I tried creating other bit-depths in Photoshop, and those work fine. Also,
the 32-bit (w/ alpha channel) render I ported over from my Macintosh reads
the correct depth.
Any input you can provide on this matter will be greatly appreciated.
ADB
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> targa file.
Actually the documentation only mentions PNG and PPM as supporting bit
depths other than 24 bpp:
"Most of these formats output 24 bits per pixel with 8 bits for each
of red, green and blue data. PNG and PPM allow you to optionally
specify the output bit depth from 5 to 16 bits for each of the red,
green, and blue colors, giving from 15 to 48 bits of color information
per pixel. The default output depth for all formats is 8 bits/color
(16 million possible colors), but this may be changed for PNG and PPM
format files by setting Bits_Per_Color=n or by specifying +FNn or
+FPn, where n is the desired bit depth."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> - Warp
Alright. I was wondering because one of the renders I brought over from my
Mac is 32-bit, but it's also type 10, rather than type 2, which means that
it's also Run-length encoded (I suspect the difference has to do with an
alpha-channel)
ADB
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> alpha-channel)
No, it has to do with the "compression" setting on the Mac side. POV-Ray can
do RLE and regular Targa iirc.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
