POV-Ray : Newsgroups : povray.programming : [Suggest] Multipass render feature Server Time
17 Jun 2024 04:06:47 EDT (-0400)
  [Suggest] Multipass render feature (Message 1 to 8 of 8)
Subject: [Suggest] Multipass render feature
Date: 21 Feb 2007 12:05:00
Message: <web.45dc7a9a65e6f1788e5923000@news.povray.org>
Reading this link
http://news.povray.org/povray.binaries.images/thread/%3Cweb.45dbe0082f42fd2caa2e049f0%40news.povray.org%3E/
And remember similar problems I have in proper experience
I think, only for a few points we need rendering entire image at slow speed
rate (ie applying higher max_trace_level or some other stuffs)
I suggest a small mod for POV, wend rendering a image with multi
frame_number, give the possibility of keep the pixels of the prior
frame_number, and rendering only the pixels with "zero render" (black dots)
in the new frame, this it makes possible to make images with multipass
render.
Activate this feature with a "+multipass" switch or so combined with
animations swiches, but the target is a static frame, not animation, we
reuse the animations routines for multipassing
example:
#if (frame_number=0) // first fast pass
  global_settings {
    max_trace_levels 5 // fast render with many black areas
#if (frame_number=1) // second pass
  global_settings {
    max_trace_levels 50 // render with some black dots
#if (frame_number=2) // final render
  global_settings {
    max_trace_levels 500 // slow render without black dots
The idea is save render time calculating a high percentage of the image at
"low trace rate", then recalculate the rays at more trace level for pixels
undefined in prior pass.
Sorry for my english
Subject: Re: [Suggest] Multipass render feature
Date: 21 Feb 2007 12:30:01
Message: <web.45dc8151edc97567c150d4c10@news.povray.org>
> render.
Perhaps I'm mistaken in the way max_trace_level works or what you are
proposing, but I don't know if this would be effective.  Max_trace_level is
just a way of specifying a maximum number of refractions/reflections per ray
to limit infite (or too large number) of refraction/reflection.  Howver,
this is an upper bound and is only used if needed.  If a ray terminates
before max is reached, it terminates, no further level is needed or used.
Essentially it already does what I understand you are suggesting.  For
example, try the following scene:
//START
global_settings {
  ambient_light 1
  max_trace_level 250 //2
camera{
  up y*image_height
  right x*image_width
  angle 60
  location <0,0,-100>
  look_at  0
light_source{y*500 rgb 1}
sphere{-y*10,20 pigment{rgb 1}}
box{-600,600
  texture{
    pigment{rgb 0}
    finish{reflection{0}}//1
//END
Essentially just a sphere inside a perfectly mirrored (or not) box.  When
setting "reflection 0", max_trace_level has virtually no effect on the
render speed, there are no reflections so, even if you have a very high
level set, it is not needed and ignored.  Setting "reflection 1",
max_trace_level has a great effect, as it now has to determine when to
terminate the ray, otherwise it would go off to infinity.
Hope this helps if I understand your intention correctly.
-tgq
Date: 21 Feb 2007 13:23:38
Message: <45dc8e2a@news.povray.org>
This is the wrong group for a feature suggestion.  This group is for
discussion of the POV-Ray source code, not general feature suggestions for
POV-Ray.  Feature suggestions for POV-Ray should be made in either
povray.general or povray.newusers.
	Thorsten, POV-Team
Date: 21 Feb 2007 22:20:00
Message: <web.45dd0b56edc975678e5923000@news.povray.org>
> -tgq
max_trace_levels not only works on mirrors, I understand ur example, but in
some cases, a high trace level slow the render, and the difference in final
result with high/low trace levels are minimal, some error dots, eliminate
these dots need great ammount of time render, could save it with some
multipass options
Please take a view to this topic:
The final result surely differs of a full slow render in one pass, but the
saved time make this aceptable.
In other side, max_trace_level are not the only parameter susceptible to
change... cameras, we can add a set of clip&offset options to make a render
of multiples images in a unique image, like a four-view template of a model
(top-side-front-perspective views), maybe a two-view of a model
before/after applying a change, multipass have many aplications
Date: 21 Feb 2007 22:28:36
Message: <45dd0de4$1@news.povray.org>
Why not just re-render with a bounding box, and paste the new rectangle
into the final image?
    "I'm getting addicted to feet. Which is
     bad, because they're like $5 a pound."
Date: 22 Feb 2007 01:45:00
Message: <web.45dd3b39edc975678e5923000@news.povray.org>
>  Thorsten, POV-Team
ups, sorry
I find on internet, but "bounding box" are too generalist term
what are a bounding box?
Date: 22 Feb 2007 02:10:19
Message: <45dd41db@news.povray.org>
  I think that what you are looking for is this:
http://povray.org/documentation/view/3.6.1/258/
Date: 23 Feb 2007 17:26:36
Message: <45df6a1c@news.povray.org>
Sadly the advice about max_trace_level in that thread (by two other users)
was plain wrong :-(
	Thorsten, POV-Team
