POV-Ray : Newsgroups : povray.programming : "minus" clause Server Time
14 Sep 2025 05:41:46 EDT (-0400)
  "minus" clause (Message 1 to 5 of 5)
Subject: "minus" clause
Date: 18 Jan 2007 17:35:00
Message: <web.45aff57c945f1bc98123242a0@news.povray.org>
Pre Scriptum: Sorry for my english language.
N.B. Abstract article.
I think, may the "minus" clause be useful for "union" and "merge" ?
Often need make hole, and then allocate in this hole some object. For
example:
wall_object, window_hole_object, and window_frame_object (with glasses and
curtains :) ).
Normal way, to make it:
union{
  // making wall with hole
  difference{
    wall_object
    window_hole_object
  // making holled wall with window
  window_frame_object
Using "minus" clause:
union{
  wall_object
  MINUS window_hole_object
  window_frame_object
Difference between both cases not very match, but (I think), second case is
more readable.
Subject: Re: "minus" clause
Date: 19 Jan 2007 04:38:22
Message: <45b0918e@news.povray.org>
Andrey K. scripsit::
> example:
> curtains :) ).
> union{
>   difference{
>     wall_object
>     window_hole_object
>   window_frame_object
> union{
>   wall_object
>   window_frame_object
> more readable.
This look purely like syntaxing sugar (and it tastes bad too me).
Please draw your CSG tree for both, and explain the difference if any.
I do not see the interest, moreover it is confusing when used on
something like:
union { a
        b
        minus c
        d
would you subtract c from b or (a+b) ?
Also, how would you interpret
union { a minus b minus c d } ?
Too much ambiguity for my taste.
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
Date: 21 Jan 2007 19:30:01
Message: <web.45b404b8b920906b8123242a0@news.povray.org>
So, let`s look on
union{
  a
  b
  minus c
  d
yes, it equal to ((a+b)-c)+d
So
union{
  a
  minus b
  c
not equal to
union{
  a
  c
  minus b
Order, in which objects allocated, very significant here.
Your`s sample "union { a minus b minus c d }" is equal to next clause:
union{          // ((a minus b) minus c) + d
  difference{   // (a minus b) minus c
    difference{ // a minus b
      a
      b
    c
  d
Date: 22 Jan 2007 07:03:31
Message: <45b4a813$1@news.povray.org>
I won't reenter the fight about prefix vs infix operation. (do not
even mention postfix...)
CSG is prefix within povray SDL, so just keep it that way.
Or soon you will get a request of a reverse-polish notation for
expression. Let's do it the Forth way !
sphere{ 0,1 } MyObj =
is too easy...
1 0 sphere MyObj =
is better!
>       a
>       b
>     c
>   d
There is a shorter syntax
union {
       difference {
       a
       b
       c
   d
schafft.
Date: 22 Jan 2007 17:35:00
Message: <web.45b53ba7b920906b8123242a0@news.povray.org>
> Le Forgeron <jgr### [at] freefr>.
Yes, it was not very good idea. As result, I surrender. :)
Thanks.
