![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
POV-Ray is finally making its transition to SMP systems, which is great news
for those of us who can afford them. However, in terms of raw CPU power the
latest NVIDIA graphics cards would seem to completely blow away anything in
the way of SMP solutions this side of a research lab. Their CUDA GPU
architecture is claimed to allow up to 128 independent processing units
each running at 1.35GHz to be thrown at computationally-intensive problems.
So, my first thought was not SETI or protein folding, but POV-Ray. Given
that V3.7 is going to be fully threaded, what would be the possibility of a
CUDA version? I guess that will depend on the time and abilities of someone
with a lot more time and a lot more ability than myself...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: CUDA - NVIDIA's massively parallel programming architecture
Date: 14 Nov 2006 12:24:30
Message: <4559fbce@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
PaulSh <nomail@nomail> wrote:
> Given
> CUDA version?
I would say that basically the only possibility for this would be if a
competent C++ compiler can automatically compile C++ code for it. Other than
that, hardly.
(This is nothing new. We go back to the days of AMD's 3DNow! and Intel's
MMX and SSE: Only automatic compiler support has brought them to POV-Ray,
nothing else.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 14 Nov 2006 16:52:18
Message: <455a3a92$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No good, they're only single precision. Plus, each shader unit would
need access to the entire scene file, which would be a pain in the a**
to code.
...Chambers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to code.
> ...Chambers
The counter-rotating quad-toroidal NUMA memory bus of the 7 or 8 SPEs in
IBM's Cell Processor
(Mercury Blades, Playstation 3) would support this, though. They're dual
precision vector coprocessors and can access the global memory that the dual
core PowerPC can through a shared memory interface (as well as their own
individual local RAM).
I'm up for tackling it once the 3.7 source becomes available. I'm stalling
until then because I don't want to reinvent the full-threading wheel that I
know they've nearly finished.
I'll hold my breath for the early CVS/SVN source access ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Feb 2007 16:07:19
Message: <45d0d707@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
True, but you won't find a Cell processor on a graphics card (much less
one from NVidia). Still, I'd get a kick out of seeing POV-Ray run on a
PS3 :)
...Chambers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Feb 2007 16:42:07
Message: <45d0df2f$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Dunno. But I'd guess it would be easier to compile 3.7 to one of these:
http://www.cray.com/products/xt4/specifications.html
http://www.cray.com/products/xd1/index.html
The latter one is running Linux (AFAIK x86_64), so POV should be a piece
of cake. Of course the price can be somewhere above the "too high"
-level :p.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was just looking at this page:
http://gizmodo.com/gadgets/home-entertainment/breaking-ps3-folding-ps3-triples-folding-at-homes-computing-power-to-over
-500-tflopspflops-in-spitting-range-246664.php
It would seem that each PS3 is contributing the same CPU horsepower as 24.6
pcs on average. Therefore a Pov for PS3 might be well worth while.
I would be willing to try my best to help get this done.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to code.
> ...Chambers
According to the CUDA programming guide published by NVidia the GPGPU
architecture is as competent as any 32 bit processor. More precise
computations can be simulated using multiple registers for a computation
instead of a single register if my memory serves - so I seriously doubt
this is a serious obstacle.
The device code is written in a simple extension of C, with host code either
written to match or working through the device drivers directly from any
language capable of such.
The major difficulty involved would be preparing the pov-ray source to run
efficiently on a SIMD architecture - native code may run out of the box
through the provided compiler, but the results would be poor at best
without optimization to take advantage of the particular memory hierarchies
involved.
Sharing parse trees used in the ray tracing is actually highly efficient on
this architecture - it would be stored in memory read-only from the device
accessible from any thread (without locking). The host processor is
typically responsible for loading the parse tree, since the its preparation
is not likely to be efficient in parallel.
The biggest hurdle I am aware of is load-balancing threads to make efficient
use of the processing power available - simple subdividing the image into
unrelated render-blocks is obviously bounded by the worst-case running time
of the entire image, which may be unacceptably slow for any sufficiently
complex scene. Perhaps someone with more in-depth knowledge of the
algorithms can determine what the limiting factors of per-ray threading
would be or other techniques. (This may or may not have been addressed for
a multi-core implementation - since at worse for the naive implementation
you still have 1/n CPU utilization for a n-core system.)
Justin
see:
http://developer.nvidia.com/object/cuda.html#documentation
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.4625ceddefc6bb7494cf37ec0@news.povray.org>,
_the### [at] yahoo com says...
at news
er the
ing in
ts
blems.
ven
y of a
omeone
> > to code.
> > ...Chambers
her
n
es
> involved.
on
e
on
ent
me
or
> Justin
> see:
Umm. Sorry but: A) trying to use more registers to do the processing
adds more overhead to the process than using them does in the first
place, I think, and that presumes you can even do it effectively. B)
Most cards are not 32-bit internally, or at least do not provide 32-bit
for every register or process they perform. C) POVRay is often now
compiled for 64-bit, so... and D) Its hardly trivial to write code that
uses multi-core processing, when dealing with things that are often
quite linear in implementation. A fact that *still* results in Radiosity
and some other features being in the "not yet working" mode in the new
multi-core CPU version of POVRay already being developed. Adding in a
graphics card that would only be directly compatible with the 32-bit
compile of it just adds more headaches.
And that is my fairly inexpert opinion. I suspect that the detailed
explanation would go well past what I said and be more specific as to
why it just won't work currently. In fact, I am certain of it, since you
are like the third person to bring it up in the last year, so the
explanation for why it won't work is someplace in the archives already.
void main () {
call functional_code()
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 21 Apr 2007 14:29:24
Message: <462a5804@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> to code.
>> ...Chambers
But double precision is actually 64bit. Until recently (I don't
remember exactly which model), NVidia didn't even do full 32bit FP (that
is, single precision), but only 24. POV-Ray, for the last dozen years,
has done 64bit FP (double precision), as the extra accuracy is necessary
for the types of computations it does.
Sure, you can simulate it in the same way you can use two integer units
to simulate a fixed point number, but the result is slow. Perhaps if
Intel surprises everyone, and releases their next graphics chip as a
double precision FP monsters, we'd be able to take advantage of that,
but the current ATI / NVidia cards aren't up to the task of dealing with
POV-Ray.
> involved.
Once the 3.7 source is out, it should be much easier, as the major task
is simply fitting it to a parallel paradigm. Having already done that,
porting to different parallel architectures should be trivial (relative
to the original threading support, that is).
...Ben Chambers
www.pacificwebguy.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
