POV-Ray : Newsgroups : povray.programming : HELP !! Image used in pigment to create an isosurface problem Server Time
4 Jul 2025 04:54:24 EDT (-0400)
  HELP !! Image used in pigment to create an isosurface problem (Message 1 to 8 of 8)
Subject: HELP !! Image used in pigment to create an isosurface problem
Date: 29 Jun 2006 08:00:00
Message: <web.44a3c005a26efc189e4a59f60@news.povray.org>
Hello there,
Is it a bug or (most probable) did I miss something ?
I have this very nice image of a checker (this is just for the sake of the
example and not the image I am actually using) stored in a file called
test.pgm:
content of test.pgm:
P2
2 2
255
0 100
100 0
I am using this image in a pigment function, or whatever you might want to
call that:
#local fn_pig= function {
    image_map {
      pgm "test.pgm"
      map_type 0
      interpolate 0
      once
#local fn_pig_Height=function { (fn_pig(x, y, 0).red ) }
Then, I just call this function many times, using a loop:
#declare Pas = 0.1;
#declare Loc_x = 0;
#while (Loc_x < 1)
  #declare Loc_y = 0;
  #while (Loc_y < 1)
    #debug concat("x=",str(Loc_x,3,3)," y=",str(Loc_y,3,3)," fn_pig_Height =
",str(fn_pig_Height(Loc_x,Loc_y,0),5,5),"n")
    #declare Loc_y = Loc_y + Pas;
  #debug "n"
  #declare Loc_x = Loc_x + Pas;
and HERE IS MY QUESTION !!! For each x value strictly lower than 1, and for
each y value stricly lower than 1 (x<1 and y<1), I get what I expect (0 or
0.39216, which is 100/255, depending on x and y). But, for x=1 and
y=anything, or for y=1 and x=anything, I get the value 1 !!
When I render this as an isosurface, I get a kind of wall around my
checker...
Could anyone help me out ?
Hope my description is clear. If not, please ask for more information...
S.
Subject: Re: HELP !! Image used in pigment to create an isosurface problem
Date: 29 Jun 2006 08:43:26
Message: <44a3caee$1@news.povray.org>
Well , i have try to uderstand .was difficult ..
Well if i understand well ..
when you got one of x,y upper than one you got a 1 ... (insteed of 0??)
well i thing that commes from your once term in your pigment function ..
when x is upper than one then you are 'ouside' your image map than that take
the value one (probably due to outside of the imagemap is white (1) ))
same for y upper than one ..
did that help you ?
news:web.44a3c005a26efc189e4a59f60@news.povray.org...
> Hello there,
> test.pgm:
> P2
> 2 2
> 255
> 0 100
> 100 0
> call that:
>   pigment {
>     image_map {
>       pgm "test.pgm"
>       map_type 0
>       interpolate 0
>       once
> #declare Pas = 0.1;
> #declare Loc_x = 0;
> #while (Loc_x < 1)
>   #declare Loc_y = 0;
>   #while (Loc_y < 1)
>   #end
>   #debug "n"
> #end
for
> checker...
> S.
Date: 29 Jun 2006 10:20:03
Message: <e80ng1$r03$1@chho.imagico.de>
Sylvain wrote:
> Hello there,
This is not the appropriate group for such questions.
http://www.imagico.de/ (Last updated 01 Jun. 2006)
Date: 29 Jun 2006 10:36:22
Message: <44a3e566$1@news.povray.org>
Sylvain wrote:
> Hello there,
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code, not general questions of using POV-Ray.  Questions
about using POV-Ray should be asked/made in either povray.general or
povray.newusers.
	Thorsten, POV-Team
Date: 29 Jun 2006 12:25:00
Message: <web.44a3fed959dd718f5847c8f80@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
> Sylvain wrote:
> > Hello there,
> povray.newusers.
>  Thorsten, POV-Team
Sorry about the mistake...
Date: 29 Jun 2006 13:14:48
Message: <44a40a88$1@news.povray.org>
   Perhaps this group could just be deleted? The vast majority of
posts are off-topic, and the few truely on-topic posts could have
perfectly been posted in eg. p.advanced-users.
Date: 30 Jun 2006 04:04:35
Message: <44a4db13$1@news.povray.org>
in fact i this this group dont have an appropriate understandable title
..cause programming can be ambiguous if you consider that building a scene
is programming it ..(as new users) ..
povray.source.programming will be less ambiguous ...
Well still off topic ....
news:44a40a88$1@news.povray.org...
Date: 30 Jun 2006 07:04:48
Message: <44a50550$1@news.povray.org>
   It has been known for many years that this group *can't* have
an unambiguous title. There have been probably a couple of dozen
suggestions, all of which have been ambiguous or very unclear.
   Given that the amount of on-topic posts in this group is really
really small and the amount of off-topic posts is very high, I vote
for removal. This group doesn't serve its purpose (and the few posts
which are on-topic could be handled in another group).
