POV-Ray : Newsgroups : povray.programming : speed up povray by recompiling for graphics card Server Time
1 Apr 2026 17:25:23 EDT (-0400)
  speed up povray by recompiling for graphics card (Message 1 to 9 of 9)
Subject: speed up povray by recompiling for graphics card
Date: 18 Jun 2006 01:50:01
Message: <web.4494e8a94ad1379aa6bb2e320@news.povray.org>
gpgpu.com
this site shows how to make a graphics card do all sorts os stuff.
if povray were recompiled for graphics card, then it could run between 4-16
times faster depending on the card. i of course am not going to attempt
anything like this any time soon, im no good at C++ yet.
this would also free up the cpu for any thing you want while your gpu is
churning away.
have fun with this idea
Subject: Re: speed up povray by recompiling for graphics card
Date: 18 Jun 2006 14:29:05
Message: <MPG.1eff4956b259aeb0989f28@news.povray.org>
In article <web.4494e8a94ad1379aa6bb2e320@news.povray.org>,
i.l### [at] gmailcom says...
> gpgpu.com
16
> churning away.
No it couldn't, because graphics cards ***do not*** raytrace, then
scanline. The basic fundamental architecture of the scene generation,
math and even how some things are tested against is *completely*
different. It would be like me telling someone who uses traditional wood
sculpting tools to make wooden chests that he would be much better off
using a paper + resin 3D prototyping machine to make thousands of
identical parts, then simply bang them together at the end to produce
thousands of identical wooden chests. Yes, you could, with a lot of
effort, a completely rethink of how the basic design needs to be handled
for it to work at all, and a total disregard for the qualitative
differences, manage to make lost of identical prefab chests, but that
would make you Wal-Mart, not a professional wood sculptor. Using scan
line cards to try to duplicate what POV-Ray does would make you into
something like Cyan, not a raytracer, with the same added effort to come
close to what you intend, the same complete rethinking of how basic
things need to be done to work and a complete disregard of "quality".
GPUs are not designed for, capable of, or likely to ever be able to
(without a fundamental redesign of their entire operation) to do what
POV-Ray does. Yes, new ones can "now" produce very good approximations
of the same results what POV-Ray was generating back when the Commodore
Amiga was a top of the line machine and no one had ever heard of a GPU.
But they still cannot do the math correctly to exactly match the
capabilities of full raytracers. And more to the point, while "some" of
the stuff done with POV-Ray, out of necessity, uses the same triangle
patch systems that GPUs "only" know how to do, the vast majority of a
complex photo realistic scene that we do with POV-Ray, while not real
time, can, as long as humans, animals or other "patch based" models are
not in it, fit in 25% of the space taken up by just ***one*** human
model for your great GPU.
That is the other thing you don't get. At some point you still have to
do the math. You can do it the way POV-Ray does and produce "exact"
mathematical versions, or you can use the math the generate
"approximations" that the GPU can handle. And it will always be an
approximation. You can't do true physical models of real world objects,
which are "not" made up of bunches of triangles, using a system that
understands nothing but triangles, can't do recursive anything, never
mind illumination, physically accurate reflections or refraction. Yes,
it can approximate reflections, at 1-2 recursion levels, maybe..., but
since its entire architecture is built on throwing out stuff you can't
"see", you can't get correct reflections off objects that are not "right
in front of your 'eyes'" in the scene. Then there is media.. POV-Ray
uses real media, GPUs use, well I don't know what exactly, save that its
more like adding a layer of fuzzy film over the stuff you want to, and
*not* real media interactions. Again, you end up approximating the real
world, instead of simply calculating how the real world would
"actually" look.
Put simply, the two techniques are completely incompatible with each
other and GPUs are by far inferior to the real physical models used in
raytracing. But heh, there is a company working to fit their raytracer
onto a programmable GPU. If/when they have a viable product, it "might"
be reasonable to reconsider. Until then, will people that favor GPUs
please stop telling us its easier to do the equivalent of building a
fish using legos than to try to actually go fishing and catch one...
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 20 Jun 2006 03:25:00
Message: <web.4497a173bda360d27d55e4a40@news.povray.org>
> scanline.
I think what's actually being referred to is using the GPU (in sufficiently
modern cards) as a fast vector processor that can be programmed to carry
out arbitrary (i.e. not triangular or scanliney) calculations. I would
actually read the headlines on that site (http://www.gpgpu.com) to see what
is being talked about. GPU pipelines are still single-precision though, and
POVRay uses double-precision maths throughout. It would be a massive job in
any case, and easier to buy more CPUs.
I don't agree. Raytracing is absolutely an approximation (e.g. no forward
light without photon maps, ignores wave physics of light, etc). Also, the
use of triangles is a separate issue (you can clearly raytrace triangles).
I would say that real-world objects are not made up of any sort of
primitive that POVRay or other renderers use, triangles included.
Certainly, I've never seen a perfect box{} in the real world (checks
furniture).
Tom
Date: 20 Jun 2006 15:37:41
Message: <MPG.1f01fc2a9ad23536989f2a@news.povray.org>
In article <web.4497a173bda360d27d55e4a40@news.povray.org>,
alp### [at] zubenelgenubi34spcom says...
> > scanline.
ly
at
nd
in
Ah.. Yeah, that could be it. Not that one couldn't sacrifice "some"
precision to gain speed that way, but it wouldn't be the same result.
Though.. It does provide an interesting solution if you want to create a
game based renderer that uses POV-Ray like function, but not quite the
same level of accuracy. Not sure how much it would truly improve the
speed though. If it could let you do refraction and reflection in a few
seconds on a complex scene, instead of minutes, it might be worth it for
an idea I had, but I wouldn't expect real time from it. lol
> furniture).
If you want to be picky, then yes. The point though is that between the
two approximations, true raytracing is closest to reality, even if you
have to round the edges of some things to make them, "not perfect
boxes". And the overhead... Like I have told several people, what you
can do in about 50 lines of POV-Ray code would take a 1.5MB mesh file,
not including textures, on most GPU based systems. From a purely
practical standpoint, GPUs are not practical for photorealism, even if
they are currently faster at producing results.
void main () {
  else
Date: 20 Jun 2006 16:55:00
Message: <web.44985e8dbda360d27d55e4a40@news.povray.org>
Essentially the GPU would be an alternative CPU. It would execute the same
raytracing algorithms as a CPU would.
> boxes".
They both capture some aspects of the way light behaves. Neither of them are
noticably faithful to "real light". Many raytracers do not support anything
but the famous triangle soup. The box primitive is just another idealised
mathematical abstraction that needs work to resemble reality.
The original suggestion was that it is possible to use a GPU as a fast
floating point processor, and a claim was made that POVRay would benefit. So
the GPU would run POVRay. There are lots of caveats (few of which derive
from the scanline heritage of GPUs). I personally can't see how it would be
worth the time, and think that the benefits are minimal compared to running
on the CPU, but it wasn't being suggested that some sort of super-GPU would
take POVRay on with scanline techniques, as far as I could tell.
These days I find myself using mainly meshes in POV (I don't do much/any
abstract work). Compactness is to be prized, but only if it actually
resembles what you want. I model planets with sphere primitives, starships
with meshes.
> From a purely practical standpoint, GPUs are not practical for photorealism,
> even if they are currently faster at producing results.
I don't know about that - scanline methods (grab-bag that they are) have
been the only commercially viable (extremely practical, no?) route to
photorealism for some time, and GPUs are probably the fastest
implementation of that technique available "by weight". They are only
getting more capable as time goes on.
I think it's clear that scanline will have to lose out to raytracing and its
derivatives in the end, but if it's good enough for ILM I think it's
probably not fair to call it impractical. It's sometimes said that pure
raytracing produces images that are too clean to be photorealistic. That's
got as much basis in fact, but doesn't reflect (yes) the potential of the
technique any more than, say, Quake does of scanlining.
Tom
Date: 21 Jun 2006 16:14:21
Message: <MPG.1f0356624ecdf8a9989f2c@news.povray.org>
In article <web.44985e8dbda360d27d55e4a40@news.povray.org>,
e
Yeah. For what I want that might be usable, though it only adds a layer
of additional complication, given I don't yet understand the math, never
mind the code to use the GPU. lol
> > boxes".
are
ng
True.
 So
be
ng
ld
s
> with meshes.
Well, a lot of stuff you have no choice. Even Isosurfaces have some
flaws, like not being able to self bound in a way that would knock off
bits that stick out where they shouldn't be. Like the one short code
contest entry, where it you render it at higher res it because obvious
that bits of the "rock" are floating in space. Not impossible to fix but
it adds something else to it that has to be later differenced out to
make it right. I am just looking at it from the perspective of the fact
that you are forced to cut corners. If even 20% of something in a game
was possible using more simplistic primitives, then that is 20% of the
objects you don't need to build out of triangles. This means more space
on the game disc for the "game" and less bandwidth for all the stuff you
have to feed to a player for an online one. Even if all you are
producing is still images, you are still looking at a "huge" data spike
every time they need to transfer a new model, or worse, an entirely new
room. Real time lighting changes, etc. have to be done in the game
engine, not generated on the other end, because if you don't cache the
files to produce it, you are looking at that same data hit every time
you enter the room. Some of that you want to do on your end anyway, but
I was looking in terms of treating the "script" for the images the same
way LPC works on a mud. The moment any change is made, looking at thing
again generates the changes on the player end, with "minimal" intrusion.
Yeah, if you are making a major motion picture and have lots of money to
buy a mess of computers, the best available software tools and people
that know how to use them, and you are planning on having the final
project come up 5 years from now, great. If you want it to update more
or less real time, make changes on the fly and people are going to be
getting the content over the internet (possibly not all on the "best"
high speed connections), then from that perspective the current
architecture is not practical. If anything its amazing some things like
Uru Live or the shard projects branching off of it, work at all over the
internet, even with high speed, same with Second Life or other "true" 3D
worlds. Heck, the isometric ones only really work because they require
installing patches with the new models and textures to extend the game.
If you couldn't buy a disk and install it, maybe 50% of the players
would never go past the first version.
Anyway, that is the standpoint I am coming from. Not, "how do I make a
photo?", but, "how do I do this without shoving 4GB of data onto
someone's computer, then cramming as much stuff as I can down the pipe
anyway when they play the game?" The later is why new content is not
exactly a staple for graphical online games. lol
Now, if using the scanline system "could" allow approximation of the
primitives at a decent speed and still make things faster.. That could
help too. But its still not going to be doing "some" things very well
without a lot of cludging, like reflecting objects not "in view", etc.
It is an issue made all the more complicated by the fact that if I
wanted to really do something, most of the books that provided clear
information on how most of the raytrace stuff where last published...
15-20 years ago. :( Now, its sort of a "turtles all the way down" world,
where everyone "assumes" you are just going to use blender to make a
model, then throw it at a GPU. Quite annoying and I am way to lazy to
spend weeks trying to find the information online (all the while dodging
site that refer back to GPUs) or probably even longer trying to figure
out what the code it POV-Ray, which I can't actually use anyway the way
I want, works. Oh well...
But yeah, for some things GPUs are practical. If you have a) bandwidth,
b) storage space, c) money and d) a lot of time. If a and b are limited
and your intent is to avoid a lot of c and d, especially if d is the one
thing you want to avoid needing, you are screwed when using GPUs. ;)
void main () {
  else
Date: 21 Jun 2006 19:05:01
Message: <web.4499d00dbda360d27d55e4a40@news.povray.org>
Hm, well, that webpage is probably a place to start :)
Isosurfaces are one of those things that I've never had the patience for,
although from some perspectives they're a way to compress enormous amounts
of data.
I don't write games, but I hear from friends who have that bottlenecks in a
combined CPU/GPU rendering system can be in surprising places, like in
switching materials, rather more than actually getting those things onto
the card's memory in the first place.
Looking at the sort of models that games involve, about the most likely
substitute as a primitive would be variations on bicubic patches - I can't
imagine most primitives being worth the effort. I think the point is very
weak as far as storage goes, it's far cheaper than CPU in my opinion, but
bandwidth is, yes, expensive.
The point about bandwidth has been examined in various interesting ways. I
don't know if you've seen the .kkreiger first-person shoot-em-up (I think
that's its name). It's about 100kb in size and uses clever compression
techniques (sort of procedural, I suppose) to pack in what's alleged to be
several gig of data. It spends about 2 minutes uncompressing chunks of that
when you load it up.
There was also a PC game called Sacrifice which was alleged to store special
effects meshes as procedures. One use of, what I suppose you could call this
procedural geometry is that you could perhaps tie it to machine speed -
faster machines take the procedural description and tesselate it into more
renderable primitives (triangles) than slower machines, the appropriate
level being determined by the user at set-up time.
> Even if all you are
> room.
I don't think that's particularly fatal (I assume you're talking about some
sort of still renderer here). Most renderers for that, scanline, raytracers
or whatever, have a big set up hit. POVRay has the parsing phase and image
texture loading, for example. Specifically in regard to the GPU, well, it's
typically got the widest bandwidth of all in a typical PC, IIRC. It might
even be faster to send data to a GPU renderer than it would to fetch it
from main memory to the CPU, I'm not sure.
> you enter the room.
Again, I'm not sure that this is as significant as it appears.
Well, let's take the opposite end. Logos for adverts and TV special effects
shots (like in scifi series) are typically done on a relative shoestring
(i.e. less than it would cost to build a physical model) and need to be
done last week. They don't raytrace either.
They will eventually, though.
Well, broadband connections are spreading very rapidly, I think. My only
experience of low-bandwidth "over-the-network" 3D is VRML-style interactive
stuff, and to be honest, back when I saw it my impression was that it was
both academic and a bit pointless at the sort of quality you'd get on a
low-bandwidth connection. One major producer of PC games (and many
sharewhere producers) has moved to distributing their products over the
internet as a first, rather than second choice. The problems the majority
of internet-based games face are more to do with latency and reliability
than raw bandwidth, I think.
I'm not sure the problem is with geometry. Game geometry, even mesh
geometry, is pretty lightweight. It's all those textures that make the
difference, and I don't think changing the type of primitive you use gets
you away from the need to detail surfaces. Procedurals are one alternative
but they cost in CPU time.
I think it's becoming more important. I seem to be regularly updated with
content for Half Life and derivatives, and I suppose other games will only
follow suit. They've been distributing upgrades and bug-fix patches this
way for years. Also, you could use those procedural compression tricks
again; uncompress the data into meshes on the user's computer after
downloading.
I don't know how important such effects are. You can render a reflective
sphere primitive with a raytracer and be very memory-efficient and
incidentally a perfect reflection, but it may well look less "real" than a
few hundred k of relatively memory inefficient mesh with a few MB of
displacement map and textures on it. Reflection's an interesting one;
blurred reflection is cheap in scanline, and can look more realistic to the
eye than sharp raytraced reflections, even though the latter is accurate and
the former isn't.
I'm not sure I understand. Are you talking about writing a graphics engine
for a game using raytracing instead of scanline methods, or a
high-quality/non-game rendering engine?
One thing I'd recommend is to check out the work behind
http://www.openrt.de/
I remember the papers behind it being spectacular, frankly.
I think most of these are answered above. Certainly I'd argue that
raytracing is far more time-intensive for game applications. But I don't
understand what application you have in mind.
Tom
Date: 21 Jun 2006 19:35:01
Message: <web.4499d6bdbda360d28f25b9020@news.povray.org>
"Blake Eggemeyer" <i.l### [at] gmailcom> wrote:
> gpgpu.com
> churning away.
http://www.nvidia.com/page/gelato.html
Here you go. And it is free. Limited to their cards though. And yes it is
raytrace with many primitives simulare to POVRay. An ISOsurface modal could
be built into the shader for an object as well. i have seen it on MentalRay
and Renderman so it may have already been done for Gelato.
I believe it would take way too much changing to make POVRay capable of
using the GPU and still run on so many different OS's.
Date: 22 Jun 2006 17:31:29
Message: <MPG.1f04ba1a8fd0dd5c989f2d@news.povray.org>
In article <web.4499d00dbda360d27d55e4a40@news.povray.org>,
> > Even if all you are
> > room.
me
rs
e
's
Well, I specifically meant internet bandwidth. True the card bandwidth
is not the bottleneck in such cases, its sending the data from the
server "to" the players machine. Especially if the game environment is
an extended text based one, where I don't expect everyone to necessarily
have broadband.
> > you enter the room.
Your thinking in terms of the "wrong" bandwidth here. ;)
o
ts
They don't raytrace because a) there are lot more Photoshop experts than
3D people and b) most of that sort of thing you can find cheap
alternatives for that don't raytrace. Sadly, that is one of the problems
imho, you can find ten billion applications of GPUs, very few
raytracing. Its sort of like the same situation as Linux vs. Windows. At
one time Windows was "way" better than all the alternatives and part of
that was how complicated using those alternates where. That didn't mean
the alternates where not on some level better, just at the time less
convenient. Same thing here, only without the anticompetitive BS from
the technologies manufacturer(s) to help it happen. But yeah, it is
inevitable that cards will start to do the real thing, even if in some
cases the result starts out as a hibred.
ve
Not an issue with what I plan to do. It will be still images, but the
image would be generated on the fly as needed, including, presumably if
possible, fog, media, etc.
e
D
e
True. That is why one solution is to avoid "premade" textures. I
understand newer cards support far better algorithmic textures, but then
you also have to deal with some "minimum" video hardware. Since my
intent is to try to avoid that at all possible, just so that, like the
client itself I planned to add it as an extension to, it will hopefully
run on the widest number of systems possible.
y
> downloading.
True.
a
he
and
> the former isn't.
Hmm. Yeah, but in my case the added texture isn't practical. It needs to
be as much procedural as possible, both to speed up the transfer from
the server, and the make sure that the scene "can" be changed from the
purely raw text. And yeah, compression would be used, on the entire SDL
file.
g
e
Umm. Sort of in between. The idea is to make it a plugin for clients
that can support them. Right now the only methods that exist are sort of
embedded HTML tags that retrieve and display static images. I would like
the be able to send across a link to a render file, sort of like:
<render "http:www.myserver.com\images\old_house.sdl">
And maybe even have some limited animation capability, like generating
the first image, then rendering the rest in the background and either
running it all once, or looping it. So, no, its not really a "game
engine" in the sense of a FPS, but its not something that can "really"
be done unobtrusively or quite the way I want if I where to simply try
to use POV-Ray through a loadable ActiveX control.
Those are the same people developing a true raytrace card I think. I
will definitely be looking there, but first I need to overcome two
frustrating problems I am having, a) figuring out the "correct" way to
bridge events, so I can convince the developer of the client I use to
implement something less nuts that the current UDP based system. At the
moment, you can instance objects in its various supported scripts, but
not handle their events. Of course, since 90% of the world either a)
uses only early bound events or b) some existing application that
supports late bound ones already, like IE or WScript, just getting
people to understand that you are "not" working within that environment
in the first place is like trying to explain physics using Egyptian
hieroglyphs... You first have to get past the "assumption" that you just
don't know about all the wonderfully useless existing implementations
that won't work for your project. lol
I did finally get a response on it. It amounted to, "Read 'Essential
COM' by Don Box, that is how I figured it out, but since I developed my
solution to the problem for a company, I can't tell you what it was."
Gosh! Thanks. :p
The other issue is that I have been trying to make it possible to use
design mode to "edit" a layout for a window, so that people can set up
the layout of forms they want, and place "any" control they want on
them. The closest I have gotten on that one is finding a truly obscure
command in ATL that "may" allow it, but even "both" books on OLE and COM
I now have make only the standard and quite useless mention of
"reading" the property and that it should be possible to "set" it for
containers as well. Umm, ok... That would be fine if 90% of the existing
documentation lists time after time that in most cases and most
languages you "can't" set it at all, so how you do it and when it is
possible are really obscure. Almost intentionally obscure... lol
The rendering part would then, if the above could be done, either a
control included with the ActiveX window that let you set design mode
and use it like an IDE form designer, or as a control that can be
instanced and added to the same, if the window where built into the
client. I know.. A lot of stuff for what is basically a text client, but
some of it "needs" to be done if you later want to develop other similar
applications too, which is entirely possible. ;)
e
Well, hopefully I have given a bit more of an idea of what I intended
with it. Most engines are inflexible by nature. It is probably not
possible to make isometric or full FPS style systems that are completely
flexible. For that text based systems like muds still rule, though stuff
like SL start to change that. But SL is "still" more of a chat room than
a "MUD", it doesn't have the elements that make for hack and slash that
most games supply on some level. So, I am aiming for the middle ground.
Good graphics for still images or limited animation, which is based on
easily edited text files (and thus may not even, for purposes of keeping
it simple, allow meshes), that can be altered as easily as the LPC code
used to built the game itself. Right now, the solutions either involve
going all the way and using Blender, or just using very simple and
limited still images that can't adjust to differences in lighting,
weather, fog, or anything else that might be part of the game world. I
want the deep well with a glint of gold at the bottom to look different
if its morning, midday cloudy or freaking pitch black and in torch
light. Existing methods would require like 30 images, each pre-made for
those conditions, and not able to adjust to how many people are there,
how many are using lights, or anything else that might alter the
"expected" results that where used to produce those images. Or, as I
said, you go all the way and end up with 2 GB of textures cached on your
system and a mess of meshes... Which is quite ridiculous if your not
playing something like Marrowind, but what is basically "text".
Basically, I want something as easy to maintain, sans talent of course,
as the script used to run the game. And for something like POV-Ray's
SDL, time can make up for talent, especially if you can make prefab
includable objects to use, which still take up less room than a mesh and
the graphics based textures.
void main () {
  else
