POV-Ray : Newsgroups : povray.programming : Can i output SDL results in a textfile? Server Time
23 Mar 2026 04:07:58 EDT (-0400)
  Can i output SDL results in a textfile? (Message 1 to 3 of 3)
Subject: Can i output SDL results in a textfile?
Date: 6 Apr 2006 10:00:00
Message: <web.44351d74fab3a6433d9284750@news.povray.org>
Hello Everybody, First..i would like to thank to all those who responded and
helped me with my previous quistion.I am verymuch new to povray/ray tracing,
i have a question regarding SDL.
1) is it possible to output the result of a macro in SDL into a text file??.
For example if i write a macro which would do some looping operations.. and
give out some result.. can i output this result in a file?. can i do this
with SDL or should i look into the source code of the programme.(if yes
please..
let me know where)
I would be verymuch thankful to anyone who can help me out with my problem.
thank you very much in advance
cheers
amar hegde
Subject: Re: Can i output SDL results in a textfile?
Date: 6 Apr 2006 10:40:01
Message: <web.4435280cba7394e26c4803960@news.povray.org>
> please..
> let me know where)
SDL will do what you want (3.2.2.3  File I/O Directives)
basically you need to create a file for input (#fopen)
then write a text string in your loop corresponding to the scene file
operation.
eg:
//start
#fopen OutFile1 "LoopOutput.txt" write
#local RND=seed(1);
#local i=0; #while (i<10)
   #local j=0; #while (j<10)
      #local k=0; #while (k<10)
         #local Rad=rand(RND)*0.5;
         sphere {<i,j,k>, Rad pigment{rgb 1}}
         #write(OutFile1,"sphere { ",<i,j,k>", ",Rad," pigment{rgb 1}}n")
      #local k=k+1; #end
   #local j=j+1; #end
#local i=i+1; #end
#fclose OutFile1
//end
-tgq
Date: 10 Apr 2006 12:47:33
Message: <443a8c25$1@news.povray.org>
That's how my mesh generator macros work.  It makes it much easier to use the
resultant meshes.
>> please..
>> let me know where)
> operation.
> eg:
> //start
You can do this also:
#macro RndBalls(oFile,oSeed)
> #fopen OutFile1 oFile write
> #local RND=seed(oSeed);
>       #local k=k+1; #end
>    #local j=j+1; #end
> #local i=i+1; #end
> #fclose OutFile1
then
RndBalls("rballs.inc",1)
#declare rBalls = union( #include "rballs.inc" )
> //end
> -tgq
David Wallace
TenArbor Consulting
"Just In Time Cash"
www.tenarbor.com
1-866-572-CASH
