POV-Ray : Newsgroups : povray.programming : Segfault due to short int overflow at bbox.cpp:596 Server Time
29 Aug 2025 13:13:32 EDT (-0400)
  Segfault due to short int overflow at bbox.cpp:596 (Message 1 to 2 of 2)
Subject: Segfault due to short int overflow at bbox.cpp:596
Date: 27 Dec 2005 00:00:01
Message: <web.43b0c972a307566187938cd40@news.povray.org>
POV-Ray 3.6.1
bbox.cpp:596
If there are too many (>32k) infinite objects, the short int index 'i'
overflows
and attempts to reference Infinite[-32767], which naturally spews core.
I suggest throwing an error in the case of overflow, and perhaps bumping up
'i' to an unsigned int, if there's any sane scene that uses 32k infinite
objects.
Less critically, I'd suggest moving the declaration of 'i' to the top of the
block enclosing the 'for' loop, or into the 'for' loop itself. It would
make the code a little easier to read, though I don't know what your coding
standards are.
-Eric
Subject: Re: Segfault due to short int overflow at bbox.cpp:596
Date: 29 Dec 2005 11:40:04
Message: <dp1384$ltk$1@chho.imagico.de>
Eric Buddington wrote:
> POV-Ray 3.6.1
> bbox.cpp:596
> overflows
> objects.
Seems correct although to be consistent with other places
(Build_Bounding_Slabs) you should use 'long'.
> standards are.
This code is quite old so the declarations obey older restrictions.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
