POV-Ray : Newsgroups : povray.programming : Att variable in lighting.cpp Server Time
11 Nov 2025 01:40:14 EST (-0500)
  Att variable in lighting.cpp (Message 1 to 4 of 4)
Subject: Att variable in lighting.cpp
Date: 5 Dec 2005 21:50:01
Message: <web.4394fb6c57e304dee49f817c0@news.povray.org>
Hi there,
What is the meaning of the Att variable in method "compute_lighted_texture"?
It is computed
using the fomula
Att = (1.0 - (LayCol[pFILTER]*max3(LayCol[0],LayCol[1],LayCol[2]) +
LayCol[pTRANSM]));
Thanks,
Jing
Subject: Re: Att variable in lighting.cpp
Date: 5 Dec 2005 22:48:21
Message: <43950a05$1@news.povray.org>
> It is computed
> using the fomula
> LayCol[pTRANSM]));
Attenuation.
	Thorsten
Date: 6 Dec 2005 16:10:01
Message: <web.4395fd28a4ef11a8e49f817c0@news.povray.org>
Could you tell me what kind of attenuation of Att is, such as Light-source
attenusation or Atmospheric attenuation, and where the original formula
comes from?
Thanks,
Jing
Thorsten Froehlich <tho### [at] trfde> wrote:
> > It is computed
> > using the fomula
> > LayCol[pTRANSM]));
> Attenuation.
>  Thorsten
Date: 7 Dec 2005 10:11:58
Message: <4396fbbe$1@news.povray.org>
Hash: SHA1
> comes from?
1. Learn to quote, please.
2. Read your own text...
 the function is compute_lighted_texture, so what do you believe is
happening there ?
Att is a scalar coefficient used to dim the texture... now consider what
pFilter and pTransmit might reference, and try to draw the relevant curves.
Then look where Att is used (just a few lines after the one you cited)
the only caveat I would have about the filter mechanism is that a
texture which filter must have the same reflecting color... that's part
of the used data-design, and it is not always practical.
>>>It is computed
>>>using the fomula
>>>LayCol[pTRANSM]));
>>Attenuation.
>> Thorsten
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden schafft.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDlvu9s/YJ43cSjHIRAlfxAJ0Y9GF89UvEQZLnt6NeV8n0/9EcSACbBOrC
PaTMaRfO2WcCejQ03GdsLyI=
=HZ8m
-----END PGP SIGNATURE-----
