POV-Ray : Newsgroups : povray.programming : Combining POV-Ray colors in a program. Server Time
11 Nov 2025 01:40:07 EST (-0500)
  Combining POV-Ray colors in a program. (Message 1 to 6 of 6)
Subject: Combining POV-Ray colors in a program.
Date: 30 Sep 2005 19:55:01
Message: <web.433dcf3c2c4f4f5d6240e2de0@news.povray.org>
I've been working on a program for a while that is a color picker.
Currently it only supports red, green, blue, and transmit, but I would like
to add filter support as well.  What I need to know is the math used to
create a preview color from a solid background color and a foreground color
containing transmit and filter values.  I've looked through the source code
for POV-Ray, but have some difficulty in understanding some of it.  I would
greatly appreciate it if anyone could help me out.
Subject: Re: Combining POV-Ray colors in a program.
Date: 30 Sep 2005 20:04:42
Message: <433dd29a$1@news.povray.org>
There is no real point in "previewing" a filter or transmit value as the
result does not depend on the color but that what you call the "background",
which actually means the recursive ray-tracing result color.  BUT, that is
what you cannot just compute by one simple mathematical formula ...
	Thorsten
Date: 30 Sep 2005 21:55:42
Message: <433dec9e$1@news.povray.org>
"background",
Well, if you display the color over the typical checkerboard background,
then you can filter and transmit that as the background to demonstrate the
color.
I believe the formula Allen is looking for would be something along the
lines of
red = color.red * (1 - color.transmit) * (1 - color.filter) + color.transmit
* whateversbehind.red + color.filter*color.red*whateversbehind.red
(same for green, blue)
I'm not sure if that's right. It should be in the source somewhere (though
not as clearly as this)...
 - Slime
 [ http://www.slimeland.com/ ]
Date: 1 Oct 2005 03:25:01
Message: <dhldbb$2l0$1@chho.imagico.de>
You should have a look at the docs, section 3.2.1.5 'Specifying Colors'.
  This pretty well explains the meaning of the color vector components.
You won't find a formula for this in the POV-Ray source since there
isn't any place where this needs to be calculated.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 1 Oct 2005 12:25:00
Message: <web.433eb730337688b769bc148e0@news.povray.org>
I'm not trying to get a perfect preview, because there are to many things to
take into consideration.  I just want the program to show a general idea of
what may be expected.  The following is a sample file of what I'm trying to
do.  There are two planes, a solid one in the back and a transparent one in
the front.  A sphere in front of the planes has its color computed from the
two plane colors.  The diffuse is 0.0 and ambient is 1.0.  The sphere color
should blend in with the rest (it does with only tranmsit, but not with
filter).
// Declare solid back and transparent front color
#declare CB = color rgb <0.5, 0.3, 0.7>;
#declare CF = color rgbft <0.1, 0.9, 0.1, 0.0, 0.7>;
// Compute visible color
// #declare R = CF.red * (1 - CF.transmit) * (1 - CF.filter) + CF.transmit *
CB.red + CF.filter * CF.red * CB.red;
// #declare G = CF.green * (1 - CF.transmit) * (1 - CF.filter) + CF.transmit
* CB.green + CF.filter * CF.green * CB.green;
// #declare B = CF.blue * (1 - CF.transmit) * (1 - CF.filter) + CF.transmit
* CB.blue + CF.filter * CF.blue * CB.blue;
#declare R = CF.red * (1 - CF.transmit) + CB.red * CF.transmit;
#declare G = CF.green * (1 - CF.transmit) + CB.green * CF.transmit;
#declare B = CF.blue * (1 - CF.transmit) + CB.blue * CF.transmit;
#declare CO = color rgb <R, G, B>;
// Camera
camera
    location <0, 0, -12>
    look_at <0, 0, 0>
    right x * image_width / image_height
    up y
// A plane in the back
plane
    -z, 7
    texture
        pigment
            color CB
        finish
            diffuse 0
            ambient 1
// A plane in the front
plane
    -z, 8
    texture
        pigment
            color CF
        finish
            diffuse 0
            ambient 1
// An object with the same visible color
sphere
    <0.5, 0, -9>, 0.2
    texture
        pigment
            color CO
        finish
            diffuse 0
            ambient 1
> Christoph
Date: 2 Oct 2005 16:05:01
Message: <web.43403c5a337688b78965f9b20@news.povray.org>
I've added the feature using the formula suggested by Slime (thanks).  It
seems to work reasonably well for its purpose.  If you would like to see
it, visit povcolor.sourceforge.net or sourceforge.net/projects/povcolor.
Any additional comments on the preview mechanism is appreciated.
