POV-Ray : Newsgroups : povray.programming : function helps with splines?? Server Time
11 Nov 2025 01:40:08 EST (-0500)
  function helps with splines?? (Message 1 to 2 of 2)
Subject: function helps with splines??
Date: 19 Jul 2005 18:20:01
Message: <web.42dd7b77fecffd8e547270140@news.povray.org>
Hello!
I am looking for a function that helps me with splines.
I want to give the function the ***exact*** start point (x1,y1,z1) and end
point (x2,y2,z2) of an spline and the height (h) of it - nothing more.
All other things should be figured out by the function.
The spline stands in a right angle to plane below.
The stuff in the function should be something similar to what you see below
the message.
A sphere i moved along the spline.
The Problem is to get the points ***exactly*** to a given start and end
position (x,y,z). I'd line to begin the first sphere exact at (above) the
star-point xyz.
I really like to have a functon doing it.
Thanks a lot!
Chrisir
#declare MySpline =
  spline {
    cubic_spline
    -0.25,<-1,  -1.6,-.85>
   0.10, <-.87,1.05,-.85>
   0.80, <.64, 1.1,.6>
   1, <1.8, -1.4, 1.1>
#declare ctr = -.3;
#while (ctr < 1.2)
  sphere {
    MySpline(ctr), .05
    pigment { rgb <0.5,1,0> }
  #declare ctr = ctr + 0.01;
Subject: Re: function helps with splines??
Date: 20 Jul 2005 02:35:05
Message: <42ddf099$1@news.povray.org>
Chrisir wrote:
> Hello!
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code.  Questions about using the POV-Ray should be asked
in either povray.general or povray.newusers.
     Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Visit POV-Ray on the web:
