POV-Ray : Newsgroups : povray.programming : POVRay for BOINC Server Time
13 Dec 2025 03:54:13 EST (-0500)
  POVRay for BOINC (Message 1 to 2 of 2)
Subject: POVRay for BOINC
Date: 8 Jun 2005 06:20:01
Message: <web.42a6c5b430827fa0fa73c15b0@news.povray.org>
Hi.
Is there anyone here working on getting POVRay available as a BOINC project?
BOINC : Berkeley Open Infrastructure for Network Computing is available at
http://boinc.berkeley.edu.
BOINC basically allows multiple projects to run across thousands of
computers and all the results correlated at a single point. Distributed
processing basically.
There is a set of projects already available for BOINC. Seti, Climate
Prediction, etc.
The old SETI@Home program has become a BOINC project.
But, other projects can be developed.
With the thousands of unused CPU cycles available, some of the MASSIVE
rendering projects could be completed a LOT quicker by sharing the load
around.
I am a programmer, but have not worked in C for a LONG time, but I am sure
that converting POVRay to a BOINC project would be an very interesting
project.
Especially as some of the animation rendering can take months to achieve at
high resolutions.
Richard Quadling.
Subject: Re: POVRay for BOINC
Date: 11 Jul 2007 10:30:02
Message: <web.4694e8f5d6d9d61c16c70d790@news.povray.org>
Hello Richard.
BOINC is not very suitable for POV for 2 good reasons.
1) Some POV tasks can't be run on separate clients if you use radiosity or a
macro that output datas.
Each node would do the rad (or macro) and sometimes it's the big part of an
image.
2) Privacy. Each node would get the source to be rendered.
Would you let your sources available to everyone ?
SETI for example is a public project, your images may not be public.
I think POV should evolve and have its core functions redefined to implement
a master/slaves architecture.
This way, a "master" console would dispatch its tasks to connected nodes,
including radiosity and macros.
 Luc H.
"richard dot quadling at bandvulc.co.uk" <richard dot quadling at
bandvulc.co.uk> wrote:
> Hi.
> Prediction, etc.
> around.
> project.
> high resolutions.
> Regards,
> Richard Quadling.
