POV-Ray : Newsgroups : povray.programming : Explanations of the source code Server Time
28 Sep 2024 17:49:22 EDT (-0400)
  Explanations of the source code (Message 1 to 6 of 6)
Subject: Explanations of the source code
Date: 31 May 2005 04:55:01
Message: <web.429c2626dd344c85367138710@news.povray.org>
Hello.
   I want to test different algorithms of visualizing fractals described by
IFS. The goal is to improve them so I need to modify the source code (I
cannot simply use macros).
   Is there a 'tutorial' or a short description of how is done the source
code ? (UML diags, where are located the main functions, etc...)
Thanks
L Magnin
Subject: Re: Explanations of the source code
Date: 31 May 2005 07:55:28
Message: <429c50b0$1@news.povray.org>
Not that I know of, but the scene object parts of the source code are
generally quite easy to follow :)
Take a look at any of the existing scene object source files (I suggest
starting with a simple one like Sphere or Box) and you can see all the
basics.
-Ryan
Date: 31 May 2005 18:14:03
Message: <87op91dlkm3dkf4c7fh1cn37p4r44694pk@4ax.com>
L Magnin,
There's a basic description of the source code layout in the MegaPOV
1.1 help file here:
http://megapov.inetart.net/manual-1.1/internals.html#sources
I'm sure your looking for more detail than this, but I figured it
would provide a jump-start.
Kyle
On Tue, 31 May 2005 04:54:24 EDT, "Celui" <lmagnin AT ens-lyon.fr>
wrote:
>Hello.
>Thanks
>L Magnin
Date: 1 Jun 2005 16:44:06
Message: <429e1e16@news.povray.org>
If I understood the announces correctly, a lot of the code has been
changed dramatically for 3.7. So you might want to wait for its sources
to be published before starting. If you don't need the 3.7 features, go
with 3.6 (so you can start right now) ;)
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 2 Jun 2005 03:00:00
Message: <web.429ead62b34bf2ab367138710@news.povray.org>
Does that mean povray will now be written correctly (using *real* C++ )?
That can be a very good idea ! But, I wish I couldn't wait. (My boss, you
understand...)
Celui //
Date: 2 Jun 2005 03:15:39
Message: <429eb21b$1@news.povray.org>
AFAIK there was lots of progress in that direction. I don't know for
sure, though, and the only way to really find out will be to wait for
the sources ;)
> understand...)
Then go ahead and use 3.6. Most probably, you won't need the new
features of 3.7, and if you do, you can still port your patch afterwards :)
HTH,
Florian
