POV-Ray : Newsgroups : povray.programming : Executing Povray from Java program Server Time
4 Jul 2025 05:01:50 EDT (-0400)
  Executing Povray from Java program (Message 1 to 3 of 3)
Subject: Executing Povray from Java program
Date: 27 Nov 2004 06:55:01
Message: <web.41a869a24bf6a9e757dde2410@news.povray.org>
I want to run Povray from a Java program with a command line in the form:
<povray> +I<input> +O<output> +D +W800 +H600
I use the Runtime.exec(String) method and it works fine when input and
output files do not contain white spaces.
So I tried several other methods :
Runtime.exec(String) with <povray> +I'<input>' +O'<output>' +D +W800 +H600
Works under Windows but not under Linux
Runtime.exec(String) with <povray> +I"<input>" +O"<output>" +D +W800 +H600
Does not work under Windows (Linux not tested)
Runtime.exec(String[]) with { <povray>, +I'<input>', +O'<output>', +D,
+W800, +H600 }
Is there a way to run correctly Povray from a Java program ?
I had a quicklook at povray source code and it seems there is some tweaking
made on the command line arguments.
TIA for any help.
Nicolas
Subject: Re: Executing Povray from Java program
Date: 27 Nov 2004 09:20:01
Message: <web.41a88c1bc3d92df83ff8d6ec0@news.povray.org>
I can`t tell you how to do it in java, but there is a tool where you might
find what you need in the sources:
http://aoi.sf.net
Or you might ask in the forum from http://jpatch.sf.net , it is quite
active, and there are at least two guys with experience in java and povray
(Sascha and David)
Greets, Mark
Date: 27 Nov 2004 10:16:53
Message: <41a89a65@news.povray.org>
In article <web.41a869a24bf6a9e757dde2410@news.povray.org> , "nvervell"
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code.  Questions about using the POV-Ray should be asked
in either povray.general or povray.newusers.  Platform specific questions
should be asked in povray.windows, povray.unix or povray.macintosh .
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
