POV-Ray : Newsgroups : povray.programming : I found a bug in povray source code 3.6... Take a look... Server Time
23 Mar 2026 07:39:06 EDT (-0400)
  I found a bug in povray source code 3.6... Take a look... (Message 1 to 2 of 2)
Subject: I found a bug in povray source code 3.6... Take a look...
Date: 19 Sep 2004 18:45:01
Message: <web.414e0af6e2bfad144e1dae950@news.povray.org>
Hello,
I think to have found some bugs in povray's source code version 3.6 (should
be the latest). More precisely, I found a problem in the way you compute
normal for a bezier patch (file: bezier.cpp). To say the truth, I think
that it's only a typo, but however... :)
Take a look at the following function (cut & pasted from bezier.cpp):
static DBL determine_subpatch_flatness(VECTOR (*Patch)[4][4])
  int i, j;
  DBL d, dist, temp1;
  VECTOR n, TempV;
  VECTOR vertices[4];
  Assign_Vector(vertices[0], (*Patch)[0][0]);
  Assign_Vector(vertices[1], (*Patch)[0][3]);
  VSub(TempV, vertices[0], vertices[1]);
  VLength(temp1, TempV);
  if (fabs(temp1) < EPSILON)
     * Degenerate in the V direction for U = 0. This is ok if the other
     * two corners are distinct from the lower left corner - I'm sure there
     * are cases where the corners coincide and the middle has good values,
     * but that is somewhat pathalogical and won't be considered.
    Assign_Vector(vertices[1], (*Patch)[3][3]);
      return (-1.0);
    Assign_Vector(vertices[2], (*Patch)[3][0]);
                                      +---- WRONG!!! Should be: vertices[2],
isn't it?
      return (-1.0);
    VSub(TempV, vertices[1], vertices[2]);
      return (-1.0);
  else
                                      +---- SAME ERROR HERE!!! Should be:
vertices[2]...
What you think about it?
Bye,
- Gianluca Arcidiacono (a.k.a. AGPX)
Subject: Re: I found a bug in povray source code 3.6... Take a look...
Date: 22 Sep 2004 05:03:06
Message: <Xns956C706C5562jgrimbertmeandmyself@203.29.75.35>
> Hello,
> (should be the latest). More precisely, I found a problem in the way
> you compute normal for a bezier patch (file: bezier.cpp). To say the
> truth, I think that it's only a typo, but however... :)
>       return (-1.0);
>                               vertices[2],
> isn't it?
>       return (-1.0);
Well, twice the same test, without effective usage of [2], look like a
quick copy/paste of code which lack the expected correction at the second
iteration.
So, yes, it seems there is a code error here, and let's blame the typo!
Now, go and make a scene that illustrate it...
It could be at least interesting to see if we really need a big array of
4 for Vertices... but that require to make sense of the complete
function, I do not have time for that.
l'habillement, les chaussures que le maquillage et les accessoires.
