POV-Ray : Newsgroups : povray.programming : Re: POV-Ray & KD-Trees Server Time
15 Dec 2025 20:42:48 EST (-0500)
  Re: POV-Ray & KD-Trees (Message 1 to 10 of 10)
Subject: Re: POV-Ray & KD-Trees
Date: 28 Apr 2004 22:25:01
Message: <web.4090666b66fba34228de1b160@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> >  If anyone's interested in seeing the results of my experimentation, you can
> > see them at: http://www.cs.ualberta.ca/~dneilson/raytracing.html
> I miss a scene making a lot of use of meshes.  Since they have their own
> bounding hierarchies in standard POV it would be interesing how well
> your version handles this.
 See the web page listed above. I've updated it with a couple of timing
results from Ingo's mesh maker macros.
> >  Should anyone be interested in my kd-tree code, then drop me a line. I'll
> > see what I can do about pulling the kd-tree stuff out of my codebase and
> > reinserting it into stock POV-Ray.
> Sure i'd be interested.
 I've made a patch against the POV-Ray 3.50c sources available for those
who're interested. You can grab them directly from
http://www.cs.ualberta.ca/~dneilson/povray-3.50c-kdtree-patch.tgz
 To apply the patches you'll have to:
1) Download the povray 3.50c sources from the povray web site and uncompress
it.
2) Unzip the archive into the src directory.
3) Next type "cat povray-3.50c-kdtree.patch | patch -p1" from the src
directory.
4) Lastly, run povray-3.50c/configure and modify src/Makefile to compile and
link in kdtree.cpp & kdtree.o.
 Note that the kdtree build code can require a lot of stack space. So, if
the code crashes make sure that you're running with a big stack (ulimit -s
unlimited).
-Daniel Neilson
Date: 29 Apr 2004 02:00:10
Message: <c6q5d4$1m5$1@chho.imagico.de>
I get a 403 Forbidden.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 29 Apr 2004 03:33:29
Message: <Xns94DA61F60356Dalexfalappa@203.29.75.35>
"Daniel Neilson" <dneilson@here;here.is:cs.ualberta.ca> wrote in
news:web.4090666b66fba34228de1b160@news.povray.org:
>  those
I'm particularly interested in studying your kd-tree implementation
(construction, balancing and look-up), but, as Cristoph already noticed, I
get a "403 Forbidden" error.
Maybe you have to put a link on your web pages.
Thanks for making available your code.
Alessandro Falappa
Date: 29 Apr 2004 11:45:00
Message: <web.4091224666fba342302f86c60@news.povray.org>
> >  those
 Sorry about that. Forgot to actually change the permissions on the file.
It's accessable now.
 If anyone has questions about the code, I'd be happy to try to answer them.
My email address can be found in the headers of kdtree.h and kdtree.cpp.
-Daniel
Oh! Since I didn't explicitly mention it, the patch is against the 3.50c
unix sources.
Date: 29 Apr 2004 14:15:01
Message: <c6rglm$9dr$1@chho.imagico.de>
But everything below 100000 triangles is not very useful.
My first comments:
- while the kd-tree for the main scene objects is optional and can be
turned on/off with options meshes seem always be using the kd-tree.
- in contrast to meshes blobs don't have the kd-tree bounding.
- it seems faster in a lot of scenes but i had problems with others
(isocacti.pov for example does not render).
- your patch would be much better usable if you would not modify all
source files (even if it's just the header).
Date: 29 Apr 2004 16:20:00
Message: <web.409162e666fba3427cd21ec50@news.povray.org>
 Fair enough. I reran another render for the p_bretzel.pov demo mesh, but I
changed the Iter_U and Iter_V parameters of the parameter{} block to 500
and 2000, respectively (from 50 and 200, respectively).
On my 3.0GHz P4, the render/trace times were
 BVH Mesh: 31.40 seconds
 KD-Tree Mesh: 24.65 seconds
 Also of interest is the time to parse the scene using the two different
versions (this includes the time required to build the BVH/kd-tree for the
mesh)
 BVH Mesh: 710.95 seconds
 KD-Tree Mesh: 667.54 seconds
> My first comments:
 That's true. For comparing the two I actually had two code bases. One used
the old mesh and one used the new -- exchanging the two is just a matter of
copying in the new mesh.* files and editing two lines in parse.cpp. I'd
figured it was a pretty safe assumption that no mesh would produce a
degenerate kd-tree. Easily changed, though. I'll see if I can't find some
time in the next couple days to alter that.
 I hadn't even looked at blobs, actually. Didn't even occur to me that they
might be using a BVH. I'll see what I can do about altering that as well.
 That's very odd. My version actually renders isocacti.pov just fine. Does
it print out any sort of errors, or does it crash, or does it render a
blank image, or... ? Perhaps something's wonky about your patched version?
 Fair enough. I'll do that with the next iteration of the patch.
-Daniel Neilson
Date: 29 Apr 2004 16:40:02
Message: <c6rp6k$apa$1@chho.imagico.de>
That's mostly a question of it being includable in a patch collection
like MegaPOV where we have the convention that all patches have to be
deactivated by default.
It just halts before starting to render, i assume stuck in some loop or so.
Date: 29 Apr 2004 21:55:01
Message: <web.4091b1dd66fba342302f86c60@news.povray.org>
 I just ran povray on isocacti.pov using the optimization settings present
in the Makefile that you sent me. Just give POV a few seconds. There's
something about this particular scene which makes building the kd-tree take
a little bit more time than I'd like -- I suspect it's all the rocks
intersecting with the ground. On my P4 3.0GHz machine here, it takes about
5 seconds to build the kd-tree for that particular scene.
-Daniel Neilson
Date: 30 Apr 2004 04:30:02
Message: <c6t2nf$22g$1@chho.imagico.de>
I waited for about half a minute - 48 seconds were required in fact.
So we have:
standard POV: 6s parse + 59s trace
your kd-tree: 48s parse + 60s trace
Since scenes containing a lot of small objects placed on the surface of
a large object are very common (any landscape with plants, houses, rocks
etc.) i think this is a major problem.  In a large size render the parse
time difference will of course not be so important but it would not be
possible to really replace the existing technique with your system with
such a difference.
Also note that in this scene the memory use difference is 186Mb with the
kd-tree vs. 27Mb with standard POV!
Date: 30 Apr 2004 12:35:00
Message: <web.40927f0566fba342302f86c60@news.povray.org>
> So we have:
> such a difference.
 Indeed, I'd noticed the memory requirements last night as well. It hits
that peak during kd-tree building. The resident size of the program goes
way down to normal range post-build. There are arrays allocated on the
stack at each level of the recursion during build. It really adds up.
 Note that I only suspect that it's the tonne of small objects intersecting
the ground that's causing the slowdown. I don't actually know that that is
the cause -- I've not spent a lot of time investigating it. More of an
educated guess, really.
 I actually don't think there's such a thing as a universally better
acceleration structure. That's why I'd never advocate flat out replacing
one structure with another. Rather, I'm a big fan of supplying options to
the user. Especially when supplying those options does not interfere with
the rest of the system -- as is the case with supplying additional
acceleration structures. If a user's running on a machine with a large
amount of memory, then they can try the kd-tree. Same logic as allowing the
user to turn off the vista and light buffers -- there are scenes where it's
just a horrible idea to turn them on.
 That said, if anyone knows of a better way to build a kd-tree that's at
least as fast and uses less memory, I'd be all for hearing about it.
-Daniel Neilson
