POV-Ray : Newsgroups : povray.programming : Compile a 64-bit version of Povray on Windows Server Time
16 Dec 2025 05:04:43 EST (-0500)
  Compile a 64-bit version of Povray on Windows (Message 1 to 6 of 6)
Subject: Compile a 64-bit version of Povray on Windows
Date: 16 Dec 2003 19:30:02
Message: <web.3fdfa337576c20ec53e0ca340@news.povray.org>
I downloaded the Povray source code and compiled a 64-bit version of it for
WindowXP-64bit.  When I tested it against the 64-bit machine, it complained
that there were registry entries missing.  So I installed Povray as what I
did for a 32-bit windows.  The installation went O.K.  But obviously the
components installed donot match what's needed by a 64-bit Povray exe.  It
crashed.
Is there a 64-bit version installation?  I could not find anything on
the web.  Can anyone help me to make it work?  I used Intel 64-bit compiler
versin 8.0.
Thanks!
Subject: Re: Compile a 64-bit version of Povray on Windows
Date: 17 Dec 2003 04:49:54
Message: <cf90uv83icav9ltsc3o8o731056l0ej1e8@4ax.com>
On Tue, 16 Dec 2003 19:28:39 EST, "Judy Hopkins" <jho### [at] seismicmicrocom>
> versin 8.0.
Would be command line version sufficient ?
IIRC it is possible to compile with empty config.h and add there necessary
data when compilation process will request something or compiler specific
things needs adjustement.
ABX
Date: 17 Dec 2003 10:50:03
Message: <web.3fe07a61581a6a8753e0ca340@news.povray.org>
Yes I can try command line version.  Please give more details.
Date: 17 Dec 2003 16:25:50
Message: <3fe0c9de@news.povray.org>
web.3fdfa337576c20ec53e0ca340@news.povray.org...
for
complained
> crashed.
compiler
> versin 8.0.
> Thanks!
Hello,
In Windows 64 bit, the registry is split into a 64 bit and 32bit namespace.
If you installed a 64 bit application with a 32 bit installer, you are out
of luck.
See: http://www.winnetmag.com/Article/ArticleID/25995/25995.html
Pascal.
Date: 17 Dec 2003 17:45:02
Message: <web.3fe0db49581a6a8753e0ca340@news.povray.org>
>Hello,
>of luck.
>Pascal.
how do I go about fixing it?  I've seen 64-bit Linux version working and
thought I could replicate it on the windows as well.
Date: 18 Dec 2003 03:18:06
Message: <3fe162be$1@news.povray.org>
web.3fe0db49581a6a8753e0ca340@news.povray.org...
Start the registry editor, and copy the PovRay key/values found under
HKEY_LOCAL_MACHINE\Software\wow6432Node\POV-Ray
into the HKEY_LOCAL_MACHINE\Software\POV-Ray
It may work (I don't know for sure if this is the only pov related keys ...)
Please be aware that I did not try it myself, so there is no guarantees that
it actually works.
Any winPOV insider listening ? Comments ?
Good luck.
Pascal
