POV-Ray : Newsgroups : povray.programming : PovRay on apache Server Time
4 Jul 2025 14:24:11 EDT (-0400)
  PovRay on apache (Message 1 to 4 of 4)
Subject: PovRay on apache
Date: 8 Jul 2003 04:45:02
Message: <web.3f0a839eda61587057737bee0@news.povray.org>
I would like to run povray from cgi/apache/linux.
I get Segmentation fault and strace prints:
ioctl(0, TCGETS, 0xbfffe540) = -1 EINVAL (Invalid argument)
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
If I understan this well, it tries to read terminal information
(to use it for output format later?) but there is no terminal
when it is run on apache. Similar problems (?) were already
reported but never answerd:
http://news.povray.org/povray.programming/30970/
http://news.povray.org/povray.unix/27230/
How to go around this? How to disable ioctl() in povray, or
how to define terminal on apache. Or is it something else?
Thanks
Radim
Subject: Re: PovRay on apache
Date: 8 Jul 2003 06:16:22
Message: <3f0a99f6@news.povray.org>
IIRC, someone suggested a fix for this (it's a bug in unix.cpp).
  I suppose it will be fixed in the next release.
Date: 8 Jul 2003 08:51:52
Message: <3f0abe68$1@news.povray.org>
In article <web.3f0a839eda61587057737bee0@news.povray.org> , "blazek"
That is an extremely bad idea!  By no means POV-Ray is meant for such a
security-sensitive application.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 8 Jul 2003 09:25:54
Message: <3f0ac661@news.povray.org>
  I don't think it's too dangerous to run POV-Ray under a dedicated
account using file access restrictions (both POV-Ray's own and the ones
provided by the OS).
  The only way to misuse this kind of service would be to make POV-Ray
use tons of memory, but even this can be limited by the OS (man limit).
  Naturally, no-one can guarantee that POV-Ray has no security holes,
but that's the same thing as with *every* software out there (including
apache and linux itself).
