POV-Ray : Newsgroups : povray.programming : Can someone patch POV so that you can output an isosurface as a wire frame? Server Time
2 May 2026 06:35:28 EDT (-0400)
  Can someone patch POV so that you can output an isosurface as a wire frame? (Message 1 to 10 of 78)
Subject: Can someone patch POV so that you can output an isosurface as a wire frame?
Date: 31 Oct 2002 13:30:04
Message: <web.3dc175b4282cec51d2ac4d730@news.povray.org>
When you get in close to an isosurface (at least one that's had an image map
/ picture impressed on it) you can see that it looks like a wireframe. Is
there a way to use POV-ray to write out that information as a mesh, or mesh
2?
You could then use POV-ray to do more complex wireframe/mesh modeling.
It would be a big help for those who want to animate isosurfaces.
normdoering
Subject: Re: Can someone patch POV so that you can output an isosurface as a wire frame?
Date: 31 Oct 2002 14:32:20
Message: <3dc18543@news.povray.org>
  If it looks like a wireframe it doesn't mean it is a wireframe. It probably
means that your accuracy is too low.
Date: 31 Oct 2002 16:00:28
Message: <chrishuff-6FC535.15525931102002@netplex.aussie.org>
In article <web.3dc175b4282cec51d2ac4d730@news.povray.org>,
> 2?
You are mistaken. What you see are precision errors of the intersection
solving algorithm, you probably just need to adjust your isosurface
settings.
There is no wireframe information to write out. If there were,
isosurfaces would be a lot faster.
http://tag.povray.org/
Date: 1 Nov 2002 00:10:11
Message: <3dc20cb3$1@news.povray.org>
You really can't put an isosurface to a wireframe.  You could create
approximations using an algorithm such as the marching cubes algorithm, but
it wouldn't be perfect.
I was once working on a macro that approximated an isosurface using a slight
variant of the marching cubes algorithm, but never quite finished it.
Parsing would take an extremely long time, especially if you wanted it to be
really accurate.  But the result would render very quickly compared to the
original isosurface.
-DJ
"normdoering" <nor### [at] yahoocom> wrote in message
news:web.3dc175b4282cec51d2ac4d730@news.povray.org...
map
mesh
> 2?
> normdoering
Subject: Re: Can someone patch POV so that you can output an isosurface as a wire fr=
Date: 7 Nov 2002 09:40:08
Message: <web.3dca7ae6e6f4bb4af9811eb00@news.povray.org>
>-DJ
What are marching cubes?
I like modeling with isosurfaces, but less for the use of equations to make
shapes than for its height field like feature of being able to take an
image map, a picture I've drawn in Corel photopaint, or drawn with a pencil
and scanned. The problem with the height field is that it's always "flat."
Now, a height field looks like a wire frame too up close. Also, the basic
idea of using grey scale values as z values should be easy to implement.
What's needed is a way to bend, cut, join, and otherwise manipulate the
wire frames produced.
Drawing grey scale picture is a hell of a lot more efficient way of
generating a limited type of 3D data than trying to grab vertices with a
mouse and move them around in modelers like hamanapatch and what not.
Is there a way you could make height fields more flexible? Make it so you
can bend, wrap, join height field into a 3D object, like a head or skull?
Is what I'm asking clear?
Don't tell me a height field isn't a wireframe internally... It doesn't
matter, a grey scale picture should certainly easily become a wireframe.
Date: 7 Nov 2002 10:20:32
Message: <3dca84bf@news.povray.org>
  Please see the section 7.13.1.1 of the POV-Ray 3.5 documentation.
  You talked about isosurfaces. Heightfields have nothing to do with that.
Date: 7 Nov 2002 12:05:47
Message: <3dca9d6b@news.povray.org>
The code to render height fields is strongly based upon their rectangular
shape. The way it's coded, it's able to speed up the rendering a lot just by
making use of this fact. If you distort the height field's shape, you lose
this property and the height field will render at the same speed as a mesh.
Therefore, you might as well use a mesh. You should be able to write macros
that will take a function or pigment and create any shape mesh you want from
it in a height-field like fashion.
In fact, I believe there are macros for cylindrical and spherical height
fields in the standard include files somewhere.
 - Slime
[ http://www.slimeland.com/ ]
Date: 7 Nov 2002 12:34:09
Message: <3dcaa40f@news.povray.org>
Well, height_fields indeed don't have anything to do with isosurfaces, but
height fields in general do: a function of form y - my_height_func(x,0,z)
produces one. And of course an isosurface height field is much more
flexible than a traditional one.
Date: 7 Nov 2002 13:09:43
Message: <chrishuff-A9A997.13004807112002@netplex.aussie.org>
In article <web.3dca7ae6e6f4bb4af9811eb00@news.povray.org>,
It's an algorithm for automatically creating a mesh from an arbitrary
mathematically defined object. A patented method, actually...there are
other similar non patented methods. The basic idea is to sample the idea
on a 3D lattice to find connected points on its surface.
Doing so would lose the speed advantages of a height field, you might as
well use a mesh. You could write macros to generate a mesh with all the
distortions you want, look at the height field macros in shapes.inc for
examples. Parsing will be slow, though.
It isn't, and it does matter. POV can't render wireframes, they are
impossible to raytrace. Wireframe is a rendering method where lines
(wires) are drawn to the image, not a kind of shape. Again, what you are
seeing is simply a rendering error...in this case, one I've never seen.
Date: 7 Nov 2002 13:31:14
Message: <3dcab172@news.povray.org>
Christopher James Huff wrote:
> Again, what you are seeing is simply a rendering error...
He mentioned he's using image_map functions, so I think the "wireframe"
effect is just pixelation...
