POV-Ray : Newsgroups : povray.programming : additional focal blur related option in camera Server Time
11 Jan 2026 19:55:09 EST (-0500)
  additional focal blur related option in camera (Message 1 to 8 of 8)
Subject: additional focal blur related option in camera
Date: 26 Nov 2005 09:43:57
Message: <st8m53-nt.ln1@raf256.com>
I was thinking of adding more options that controll how meany rays are taken
when rendering with focal blur.
I would like to add additional parameter, like min_samples, I want it to
behave simmilar to max_samples (when parsing), and I need to access it from
render.cpp.
What exacly should I change in the sources/where?
Subject: Re: additional focal blur related option in camera
Date: 26 Nov 2005 10:16:33
Message: <43887c51$1@news.povray.org>
Raf256 wrote:
> Hi,
> render.cpp.
Nothing. You just need to read the manual. You are looking for "confidence"
and "variance"...
<http://www.povray.org/documentation/view/3.6.1/248/>
	Thorsten
Date: 26 Nov 2005 10:49:16
Message: <incm53-upv.ln1@raf256.com>
Thorsten Froehlich <43887c51$1@news.povray.org> Saturday 26 of November 2005
16:16
> "confidence" and "variance"...
Controling of number of rays is just one of things Im trying to implement
here.
Thanks, I know about thoes settings, but IMHO they do not work as expected
in some situations, Im testing it now...
Date: 26 Nov 2005 11:05:42
Message: <438887d6$1@news.povray.org>
> here.
They do, it is just that the statistical methods they are based on are not
easy to understand without some background in statistics (and daily use).
basically, what you are trying to do will not improve things because what
you are trying to do does not fit into the statistical model at all.  You
would end up not taking samples, which would unbalance the distribution as a
whole.  This in turn would create some strong but unpredictable (probably
appearing randomly and visual as noise) bias in the samples.  Obviously this
would make things a lot worse.
	Thorsten
Date: 26 Nov 2005 12:57:35
Message: <r8km53-dc8.ln1@raf256.com>
Thorsten Froehlich <438887d6$1@news.povray.org> Saturday 26 of November 2005
17:05
> a
> this would make things a lot worse.
Concider checker plane y,0 with too small scale, it is very very aliased,
and if we are unlucky then in example first 4 rays could gave identical
result quickly fooling statistical function.
I did some testing with minimal samples setting, and It seems for checker it
is better(*) then any combination of variance/confidence/samples of regular
algorithm.
But I can be mistaking ofcourse, I will play a bit with that.
(*) better = in possible small render time eliminate the random very brights
pixels. I do not talk here about the "usual" quality of focal blur, but
about 100% green or 100% blue pixels showing when rendering very aliased
pigment { checker } plane.
Date: 26 Nov 2005 13:25:41
Message: <4388a8a5$1@news.povray.org>
>> as a whole. This in turn would create some strong but unpredictable
>> (probably appearing randomly and visual as noise) bias in the samples.
>> Obviously this would make things a lot worse.
You don't fix aliasing by taking *fewer* samples, but by taking *more*
samples.  If you are having problems with too few samples being taken, you
have poor settings for the focal blur variance.  Taking fewer samples will
certainly *not* improve the result.
	Thorsten
Date: 26 Nov 2005 15:05:58
Message: <eorm53-a5r.ln1@raf256.com>
Thorsten Froehlich <4388a8a5$1@news.povray.org> Saturday 26 of November 2005
19:25
My idea was to force blur to trace at least in example 5 first rays per
pixel, even if they are identical to eachother and even if otherwise they
will be bellow threshold,
one liner:
--- megapov-1.2.1/source/render.cpp     2005-08-23 21:20:33.000000000 +0200
+++ megapov-1.2.1+rmaj/source/render.cpp        2005-11-26
16:29:12.000000000 +0100
@@ -3119,7 +3119,8 @@
     if ((V1[pRED]  < Sample_Threshold[nr-1]) && (V1[pGREEN]  <
         (V1[pBLUE] < Sample_Threshold[nr-1]) && (V1[pTRANSM] <
Sample_Threshold[nr-1]))
-      break;
+      if (nr > Frame.Camera->Blur_Samples / 4) // raf256
+                               break;
of course it is better to just set Sample_Threshold for min_sample first
value to 0
So the idea is to bump up minimal rays traced without affecting rest of
adaptive system...
I will do some testes after weekend probably
Date: 26 Nov 2005 16:46:58
Message: <4388d7d2@news.povray.org>
Actually, POV-Ray takes at least seven samples if "blur_samples" is at least
seven...
This logic is clearly broken. It certainly does not force at least five
samples to be taken.  The division actually has no useful effect at all.
> value to 0
> adaptive system...
As I have been telling you, and as your change shows (well, would show if it
was coded correctly*), you are not understanding the way the sampling and
the threshold works at all. Your change would successfully disable the
statistical sampling method altogether.
The only time when the focal blur sampling will produce aliasing is when
dealing with some unfortunate sub-pixel-size scene details.  And *only*
then.  It will not fail for a checker pattern if configured correctly (or
using the defaults).  If nothing else, chess2.pov is a perfect example of
focal blur handing checker patterns correctly.
As such, I repeat my strong recommendation to first familiarise yourself
with the focal blur settings the SDL provides.  They are certainly
sufficient for 99.9% of cases. And with POV-Ray 3.7 you will be able to use
AA with focal blur to render the other 0.1% of cases as well.
	Thorsten
* It is also done at the wrong place, it should have been in the for-loop
further up in the function and been "|| (nr < 5)".
