POV-Ray : Newsgroups : povray.programming : C++ question Server Time
11 Nov 2025 22:12:53 EST (-0500)
  C++ question (Message 1 to 4 of 4)
Subject: C++ question
Date: 17 Sep 2001 01:51:59
Message: <se3bqtkgpn9s6piqc63h444gggamm7lah0@4ax.com>
I want to have a container of objects which stores unique entities
like a set does, but instead of rejecting the insertion of duplicate
entries, they should be deleted. Subsequent attempts to insert an
already deleted object should be rejected. How should I go about it in
the most efficient way?
Peter Popov ICQ : 15002700
Subject: Re: C++ question
Date: 17 Sep 2001 02:55:09
Message: <3ba59e4d@news.povray.org>
Peter Popov wrote in message ...
If I understand you correctly, you want a data container that, when you add
something the first time, accepts it.  If you add it a second time, it gets
deleted instead, and if you add it more times, it doesn't get added?  If
this is correct, the easiest way to do this is to add a "deleted" flag to
each object when you add it.  When you remove the object, it doesn't
actually get deleted, but instead gets marked as being deleted, so you can
see if it has already been added later.
Mark
Date: 17 Sep 2001 15:47:49
Message: <6mkcqt4q61cicae18hqk10ocni39d3b6to@4ax.com>
On Mon, 17 Sep 2001 02:55:54 -0400, "Mark Wagner"
Maybe I can use a set of objects and a separate set of deleted objects
(or rather, their IDs), as an alternative. How does that look,
programming-wise?
Date: 18 Sep 2001 00:13:35
Message: <3ba6c9ef$1@news.povray.org>
Peter Popov wrote in message <6mkcqt4q61cicae18hqk10ocni39d3b6to@4ax.com>...
>programming-wise?
Sounds like a little more work, but probably easier to debug.
Mark
