POV-Ray : Newsgroups : povray.programming : Re: Torus bug fix: images Server Time
29 Aug 2025 20:13:21 EDT (-0400)
  Re: Torus bug fix: images (Message 1 to 2 of 2)
Subject: Re: Torus bug fix: images
Date: 4 Aug 2003 04:34:36
Message: <s56siv8t74erlk9bpqg6bejpenqv0li8h8@4ax.com>
On Sun, 03 Aug 2003 12:18:31 +0200, Wolfgang Wieser <wwi### [at] gmxde> wrote:
> Image for article "Re: [Fwd:] Torus bug fix" on p.programming.
> Torus viewed from large distance: before with and without patch
> from Lars C. Hassing.
Can you verify those cases ?
http://news.povray.org/380a780c%40news.povray.org
http://news.povray.org/i344rt8ftt1ctvq3smm5f8salnaeoclpl3%404ax.com
ABX
Date: 4 Aug 2003 07:20:22
Message: <3f2e416b@news.povray.org>
Well, it seems, this bug was already fixed in povray-3.5.
After not seeing any difference between povray-3.5 patched and
unpatched, I noticed the "#version 3.1;" directive at the beginning
of the file and rendered it with 3.1g. This showed that the
black spot in the middle had a strange ill-shaped form which
is not the case with 3.5 (3.50c)
Yes, this one gets fixed by the patch. Without the patch, I see
heavy disortion, with the patch, the torus looks just as it should.
Wolfgang
