POV-Ray : Newsgroups : povray.programming : Solid meshes ? Server Time
29 Sep 2024 16:11:22 EDT (-0400)
  Solid meshes ? (Message 1 to 4 of 4)
Subject: Solid meshes ?
Date: 1 Oct 1999 10:43:44
Message: <qqmln9nnntr.fsf@goldach.fmi.uni-konstanz.de>
Hello,
some time ago, there has been a discussion about adding support of CSG
for triangle meshes. Has this been realized? Please tell me, if such
a patch exists or whether it's included in the superpatch.
I'm even more interested in using bicubic patches. CSG with objects
that are modeled with bicubic patches (e.g. within sPatch) would
be really great. Furthermore, these objects should be able to serve
as containers of media.
Thanks for any pointers.
http://www.fmi.uni-konstanz.de/~willhalm
Subject: Re: Solid meshes ?
Date: 1 Oct 1999 11:21:33
Message: <37f4d17d@news.povray.org>
On 01 Oct 1999 16:43:44 +0200, Thomas Willhalm wrote:
>Hello,
If it's not in the current one, it'll be in the next one.  I'm pretty
sure it's in UVPOV, Nathan Kopp's photon-mapping and UV-mapping patch.
If you have a union of bicubic patches, and it's watertight, you should
be able to use it as a media container even in the official POV.  Render
this, for example:
light_source { <-20,20,-20> rgb 1}
camera {location <2,5,5> look_at 0 }
#declare xface=
  bicubic_patch { type 1 flatness 0.1 u_steps 3 v_steps 3
  <1,-1,-1> <1,-.5,-1> <1,.5,-1> <1,1,-1>
  <1,-1,-.5> <1,-.5,-.5> <1,.5,-.5> <1,1,-.5>
  <1,-1,.5> <1,-.5,.5> <1,.5,.5> <1,1,.5>
  <1,-1,1> <1,-.5,1> <1,.5,1> <1,1,1>}
union {
  object {xface}
  object {xface rotate 90*y}
  object {xface rotate 180*y}
  object {xface rotate 270*y}
  object {xface rotate 90*z}
  object {xface rotate 270*z}
  hollow
    pigment {color rgbt .8 }
    finish { specular .2 diffuse .3 ambient .2 roughness .2}}
  interior { media { emission 1
    density {bozo color_map {[.5 rgb 0][1 rgb 1]} scale .2}}}
#declare sm=slope_map { [0 <0,0>][.8 <0,0>][1 <1,1>]}
plane {y,-2
    pigment {checker color rgb <1,1,0> color rgb <0,1,0> translate .5}
    finish {specular .2 diffuse .3 ambient .3 roughness .001}
    normal {average normal_map {
      [.5 marble 1 slope_map {sm}]
      [.5 marble 1 rotate 90*y slope_map {sm}]}}
    scale <3,1,3>
Date: 3 Oct 1999 00:02:04
Message: <37f6d53c@news.povray.org>
Ron Parker <par### [at] fwicom> wrote ...
> >Hello,
Yes.  I did play around with that a bit.  My solution is very simple and has
a number of flaws and shortcomings (which have been discussed previously in
this group), but has gotten the job done for me in a few situations where I
needed it.  :-)
-Nathan
Date: 4 Oct 1999 08:17:26
Message: <qqmvh8nnwve.fsf@goldach.fmi.uni-konstanz.de>
"Nathan Kopp" <Nat### [at] Koppcom> writes:
Thank you both. I'll try this.
