POV-Ray : Newsgroups : povray.programming : pov_io_base question Server Time
12 Jan 2026 11:36:55 EST (-0500)
  pov_io_base question (Message 1 to 4 of 4)
Subject: pov_io_base question
Date: 7 Oct 2002 04:36:10
Message: <nih2quouobesergu3qtvmmithvvjskjfr2@4ax.com>
Working on MPEG port I found useful to perform buffered reading: allocate
buffer and read fixed number of bytes there. The problem appear when there is
less bytes to read than specified. I have to know how much was readed. I
thought it could be useful to introduce below changes for it but since I'm not
very experienced with OOP rules and IO operations I thought I could discuss it
first. I have introduced private field 'transfered' with number of bytes
transfered to/from file and public method to get this value. I have also
changed content of read and write with reversed order of number of blocks and
size of block (I have to measure in bytes). I want to know if I do it correct
way. Perhaps direction of last transfer could be additionaly stored in sign of
transfer field. So here are my changes...
// file_pov.h
class pov_io_base
  public:
    inline u_int32 lasttransfer (void) { return (transfer) ; }
  protected:
    u_int32 transfer;
// file_pov.cpp
pov_io_base::pov_io_base (u_int32 dir, u_int32 type)
    transfer = 0;
pov_io_base& pov_io_base::read (void *buffer, u_int32 count)
  if (!fail && count > 0)
    transfer = fread (buffer, 1, count, f);
    fail = ( transfer > count ) ;
  else
    transfer = 0;
  return (*this) ;
pov_io_base& pov_io_base::write (void *buffer, u_int32 count)
    transfer = fwrite (buffer, 1, count, f);
  else
    transfer = 0;
  return (*this) ;
ABX
Subject: Re: pov_io_base question
Date: 7 Oct 2002 04:53:32
Message: <3da14b8c@news.povray.org>
In article <nih2quouobesergu3qtvmmithvvjskjfr2@4ax.com> , ABX
If you need to do that it indicates a flaw in your reading code.  Every
(reasonable) fileformat contains sufficient information to determine how
much information is in the file, and you should just never read over the end
of a file.
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Oct 2002 05:22:49
Message: <e1k2qusklku3cvqp08gljdoo4jmkj5clf2@4ax.com>
On Mon, 07 Oct 2002 10:53:30 +0200, "Thorsten Froehlich" <tho### [at] trfde>
That's not my code. I have found more difficoult limitations in libmpeg2
library I have to fix. For example the size of the buffer I had to set was...
1 byte :-)
> Every
I agree, but then... what about ascii format, in particular POV scenes ;-)
ABX
Date: 7 Oct 2002 10:21:17
Message: <3da1985d@news.povray.org>
  Usually the C(++) compiler and even the OS (and sometimes even the
hardware itself!) will do buffered reading, so from the point of view
of performance you are most probably just replicating the work which is
already done by the underlying system.
