POV-Ray : Newsgroups : povray.programming : JPEG output Server Time
23 Mar 2026 16:25:46 EDT (-0400)
  JPEG output (Message 1 to 3 of 3)
Subject: JPEG output
Date: 7 Oct 2002 03:48:23
Message: <dde2qu4ukgdd7l5h68tprm3a1bbk6ijtmb@4ax.com>
I found in parstxtr.cpp in Parse_Image that there is intelligent feature for
file recognition. It assume that when image has not specified type before
filename then it thinks image has the same type as outputed image. There is no
tiff autorecognition case becouse there is no tiff output. But there is jpeg
case. It is left by accident or becouse planned jpeg output ? IIRC there was
no plans for jpeg output - it would be mostly useless. But perhaps situation
has changes somehow ? So can I enclose it with
  #ifdef REMOVE_NOT_USED_CODE
  #endif
ABX
Subject: Re: JPEG output
Date: 7 Oct 2002 04:04:30
Message: <3da1400e@news.povray.org>
In article <dde2qu4ukgdd7l5h68tprm3a1bbk6ijtmb@4ax.com> , ABX
Not because of planned JPEG output, but because specifying JPEG output by
the user is intentionally disabled.  That does not mean here is no JPEG
output!
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Oct 2002 04:18:41
Message: <gag2qugldjdbsb7e92nfcf0ta66nlpkm5n@4ax.com>
On Mon, 07 Oct 2002 10:04:23 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> output!
Hmm. There is no switch for JPEG output, so I assumed there is no JPEG output.
'If JPEG_FILE can't appear in opts.Output_File_Type then why such case in
switch' I thought. Now, I see in optin.cpp and optout.cpp ...
ABX
