POV-Ray : Newsgroups : povray.programming : Bug in Compute_Axis_Rotation_Transform() Server Time
2 Apr 2026 13:52:02 EDT (-0400)
  Bug in Compute_Axis_Rotation_Transform() (Message 1 to 9 of 9)
Subject: Bug in Compute_Axis_Rotation_Transform()
Date: 30 Jun 2000 18:39:35
Message: <chrishuff-FACEBB.17394030062000@news.povray.org>
I ran into this when writing the particle system patch. The vector V1 is
modified by the function, which normalizes it for internal use. The
function starts off like this:
void Compute_Axis_Rotation_Transform (TRANSFORM *transform, VECTOR V1,
DBL angle)
  DBL l, cosx, sinx;
  VLength(l, V1);
  VInverseScaleEq(V1, l);
I deleted the VLength and VInverseScaleEq, and rewrote it like this:
AxisVect, DBL angle)
  DBL cosx, sinx;
  VECTOR V1;
  VNormalize(V1, Vect);
Subject: Re: Bug in Compute_Axis_Rotation_Transform()
Date: 30 Jun 2000 18:51:47
Message: <slrn8lq9q9.22g.ron.parker@linux.parkerr.fwi.com>
Not so much a bug, but a bit roundabout.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 30 Jun 2000 19:41:16
Message: <chrishuff-750029.18412230062000@news.povray.org>
In article <slr### [at] linuxparkerrfwicom>,
The use of VLength and VInverseScaleEq instead of VNormalize wasn't the
bug I was talking about...the vector passed to the function is being
normalized, when the function should create it's own copy. Since a
vector is an array, it can be modified from within a function it is
passed to.
I was using this function in some calculations for randomly changing the
particle direction, passing it the emission direction directly. Since
the direction vector in my patch specifies the speed as well as the
direction, all the particles ended up travelling at a speed of 1,
ignoring the length of the direction vector.
Date: 30 Jun 2000 21:08:35
Message: <slrn8lqhqq.2dh.ron.parker@linux.parkerr.fwi.com>
Ah, yes, that's a bug.  Please send it to .bugreports, if you would.
Date: 3 Jul 2000 06:03:30
Message: <3960661E.A3C7871A@student.uni-siegen.de>
As far as my understanding of C and the workings of the POV-type
VECTOR go, this should *not* modify the "real" V1, since the value is
passed on the stack. The V1 in the function gets modified, but *not*
the parameter that is passed, example:
int ParamFunction(int i)
   i = i/2;	// modify parameter
   return i;	// and return the result
void TestParam(void)
   int x;
   x = 5;
   printf("%d\n",ParamFunction(x));  // prints "2"
   printf("%d\n",x);                 // prints "5", i.e. "x"
This prints:
   2    5
i.e. internal to the function, the parameter "i" gets modified,
but this does *not* modify the "calling" parameter x.
This is guaranteed by the C standard.
Or is the "VECTOR" type some hidden pointer?
Markus
Date: 3 Jul 2000 07:23:09
Message: <3960784B.4394D7D4@aetec.ee>
Vector is actually array of 3 doubles, so its contents could be
modified.
Date: 3 Jul 2000 08:36:50
Message: <chrishuff-7F1D91.07365303072000@news.povray.org>
In article <3960661E.A3C7871A@student.uni-siegen.de>, Markus Becker
The type VECTOR is an array of three doubles. The name of an array is
the same as a pointer to the first element, so a function can modify a
VECTOR passed to it. The same goes for colors.
Date: 3 Jul 2000 09:32:35
Message: <39609720.5F4CA74B@student.uni-siegen.de>
OK, I stand corrected. Then it is a bug ;-)
Markus
Date: 3 Jul 2000 17:14:45
Message: <39610245@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: The type VECTOR is an array of three doubles.
  Well, strictly speaking there's no such a thing as an array in C.
  What is passed to the function is a pointer-to-double. This pointer points
to a memory location containing one (or more) double-type values. There's
no way of knowing whether the pointer points to just one double or to a
series of them, and if the latter, how many of them. You just have to trust.
  There is a pass-by-value parameter here, so the value is copied for the
function. But since the value is just a pointer, it will point to the same
place as the original one.
  Even a local "array" (like this:
void f(void)
{ double array_of_doubles[3];
) is not really an array, but just a pointer to a static memory location
which (ie. the pointer) can't be modified.
