POV-Ray : Newsgroups : povray.programming : Re: Can the trace() function be used to generate a mesh from an isosurface? Server Time
12 Jan 2026 08:48:02 EST (-0500)
  Re: Can the trace() function be used to generate a mesh from an isosurface? (Message 1 to 6 of 6)
Subject: Re: Can the trace() function be used to generate a mesh from an isosurface?
Date: 7 Nov 2002 21:30:43
Message: <chrishuff-F3DBBA.21304407112002@netplex.aussie.org>
In article <web.3dcb1deecf5e17f77748f6790@news.povray.org>,
 "normdoering" <nor### [at] yahoocom> wrote:
> I'm thinking that instead of the HF_ macros in shapes.inc that the trace
> function might be used to write a macro to generate a mesh file from an
> isosurface... Will this work?
There was a "triangle scanner" include file a while ago that did this, I
think it was written for MegaPOV. The method it used didn't work very
well, it was mainly only useful for a cheap preview.
It would theoretically be possible to duplicate the tessellation patch
in POV-Script using trace(). It'd be a lot slower, and wouldn't have any
advantages over the patch.
http://tag.povray.org/
Date: 7 Nov 2002 23:58:03
Message: <chrishuff-BE755D.23580107112002@netplex.aussie.org>
In article <web.3dcb24884533dc187748f6790@news.povray.org>,
> What was the problem? Was the macro badly written?
No, the algorithm just didn't work very well. I think it used a kind of
height field approach, maybe multiple height fields, making it
impossible to represent many kinds of geometry.
Date: 8 Nov 2002 10:08:40
Message: <3dcbd378@news.povray.org>
  Actually the patch uses internally trace() to get the intersection points
with the surface (or at least the patch which I made does). :)
  In fact, I first made the tesselation with pov-SDL with the exact same
principles as the patch itself, but it was really, really slow, which was
the reason I decided to make it as a patch.
Date: 8 Nov 2002 12:10:27
Message: <chrishuff-33B5ED.12101808112002@netplex.aussie.org>
In article <3dcbd378@news.povray.org>, Warp <war### [at] tagpovrayorg>
Well, it uses the functions that the trace() POV-SDL function uses (the
intersection methods accessed through the Intersect() macro). The
Trace() function in the source code does something else, and there is no
trace(). I know you know this, I'm just clearing it up for others.
Hmm, sounds interesting...did you ever release the POV version? It might
be useable on a more modern machine.
Date: 8 Nov 2002 15:50:18
Message: <3dcc238a@news.povray.org>
  Nope, and I can't find it anymore. I don't know what I did with it...
Date: 8 Nov 2002 22:30:21
Message: <chrishuff-3C1EF4.22301308112002@netplex.aussie.org>
In article <3dcc238a@news.povray.org>, Warp <war### [at] tagpovrayorg>
That happened to my electrical schematics include...too bad.
