POV-Ray : Newsgroups : povray.programming : #set source code Server Time
28 Mar 2026 16:04:31 EDT (-0400)
  #set source code (Message 1 to 1 of 1)
Subject: #set source code
Date: 30 Aug 2000 14:18:21
Message: <chrishuff-49FC28.13195430082000@news.povray.org>
Here are the changes necessary to add my #set patch, based on the
MegaPOV 0.5 source. More details are in the povray.unofficial.patches
group. If anyone needs help integrating the patch, just ask.
I hope I didn't forget anything...
frame.h:
Add:
#define SetPatch/*Chris Huff 2000.8.30*/
parse.h, TOKEN_IDS:
Add:
#ifdef SetPatch
  SET_TOKEN,
#endif
tokenize.h, "Global functions":
Add:
#ifdef SetPatch
SYM_ENTRY *Find_Symbol(int Index,char *Name);
#endif
parse.c, Parse_Declare():
Replace:
  if (Local_Flag=(Token.Token_Id==LOCAL_TOKEN ||
Token.Token_Id==PERCENT_TOKEN))
     Local_Index=Table_Index;
  else
     Local_Index=1;
With:
  /*Chris Huff 2000.8.30 - added #set */
#ifdef SetPatch
  Local_Flag = (Token.Token_Id==LOCAL_TOKEN ||
Token.Token_Id==PERCENT_TOKEN);
  if(Local_Flag)
  else
     if(Token.Token_Id==SET_TOKEN)
        /*Search for most recent table with an identifier with this name
        Parts copied from Read_Symbol*/
        int Idx;
        int Found = FALSE;
        Get_Token();
        /* Search tables from newest to oldest */
        for(Idx=Table_Index; Idx > 0; Idx--)
            if(Find_Symbol(Idx, Token.Token_String) != NULL)
                Local_Index = Idx;
                Found = TRUE;
                break;
        if(Found != TRUE)
            Error("#set cannot assign to uninitialized identifier
%s.\n", Token.Token_String);
        Unget_Token();
     else
        Local_Index=1;
#else
  else
     Local_Index=1;
#endif
tokenize.c, Reserved_Words:
Add:
#ifdef SetPatch
  {SET_TOKEN, "set"},
#endif
tokenize.c, static Function Prototypes:
Replace:
static SYM_ENTRY *Find_Symbol (int Index, char *s);
With:
#ifndef SetPatch
#endif
tokenize.c, Parse_Directive():
Replace:
    CASE2 (DECLARE_TOKEN,LOCAL_TOKEN)
With:
#ifdef SetPatch
    CASE3(DECLARE_TOKEN, LOCAL_TOKEN, SET_TOKEN)
#else
#endif
tokenize.c, Find_Symbol():
Replace:
static SYM_ENTRY *Find_Symbol(int Index,char *Name)
With:
#ifdef SetPatch
#else
#endif
Christopher James Huff
