POV-Ray : Newsgroups : povray.programming : Help w/ borland linker error Server Time
11 Jan 2026 21:48:59 EST (-0500)
  Help w/ borland linker error (Message 1 to 2 of 2)
Subject: Help w/ borland linker error
Date: 23 Mar 2005 04:01:48
Message: <Xns9622A9FFA091Viviblackmagevillage@203.29.75.35>
Hi all,
I downloaded the latest source from the pov site and decided to give it a
try in building under borland's compiler. I had to make a few tweaks in
the makefile.bcc and one or two of the source files. Anyway, I got all
the source files to compile as well as the pvengine.rc file compiled but
the linking phase isn't working. The ilink32 keeps crashing with a
'Fatal: Access violation. Link terminated' error.
If I omit pvengine.res then everything links fine but the pvengine.exe
doesn't run. It gives the following error in a dialog box:
Editor DLL initialisation failed[LoadLibrary failed, code is 0000007e]
following that after clicking ok, another dialog box:
See the 'Internal Editor Reference' section in the help file
and then
Failed to load internal bitmap
and finally
pvengine.exe has encountered a problem and needs to close...
I looked in the Tutorial and Reference manual but couldn't located the
'Internal Editor Reference' section that first dialog speaks of.
Finally, I did do the pov installation properly and that runs fine. Also,
the only thing I've changed in pv_engine.rc are the lines starting with
FONT 8 "...", x,x,x,x
into
FONT 8 "..."
since the borland resource compiler chokes with the extra parameters
after the string.
Any help on what the problem might be is appreciated
Thanks
Subject: Re: Help w/ borland linker error
Date: 23 Mar 2005 08:03:22
Message: <424169D2.2590EE32@gmx.de>
Vivi Orunitia schrieb:
> Hi all,
You should note that support in POV-Ray for the borland compiler was
given up quite some time ago and it is quite possible (although i can't
say for sure) that it does not support all the C++ language elements
used by POV-Ray.  The Windows version of POV-Ray 3.6 is known to compile
with the Intel C++ compiler, MSVC as well as MinGW.
-- Christoph
