POV-Ray : Newsgroups : povray.programming : [ot] tga 16 gray Server Time
23 Mar 2026 16:28:38 EDT (-0400)
  [ot] tga 16 gray (Message 1 to 2 of 2)
Subject: [ot] tga 16 gray
Date: 22 Sep 2002 13:30:09
Message: <Xns9291C6607BBF0raf256com@204.213.191.226>
Hello,
where can I find description of 16 bit gray .tga format ?
Or maybe there is some other format more easy to implement (I want to make
a little utility for generating landscapes)
Subject: Re: [ot] tga 16 gray
Date: 22 Sep 2002 15:04:42
Message: <pr4sou074hmfl1gk3pkoirijud1cgor7n1@4ax.com>
The HF_Gray_16 format POV-Ray uses is just a normal three-channel
(RGB), 8 bit per channel, TGA format. However, the way POV interprets
the data is different. Of the three bytes that form each pixel, the
first two - red and green - are treated as a 16-bit word, and the
third one - blue - is ignored. It's quite simple, actually, so any
code you find that writes TGA files can suit your needs.
Peter Popov ICQ : 15002700
