POV-Ray : Newsgroups : povray.programming : own output format Server Time
30 Aug 2025 19:49:05 EDT (-0400)
  own output format (Message 1 to 4 of 4)
Subject: own output format
Date: 22 Aug 2002 20:34:01
Message: <Xns92731979CD95Draf256com@204.213.191.226>
Hello,
what steps should I do to create own text output format ?
output file will be like :
width height
line1
line2
line3
where lineN is :
pixel1 ; pixel2 ; pixelN
where pixel is :
r,g,b,x,y,z,normal_fi,normal_theta,distance,alpha,id,cpu_time
so I want to access all above informations (id-see next post, cpu_time -
cpu utilization histogram, assuming that histogram is same size as output)
Subject: Re: own output format
Date: 23 Aug 2002 09:41:03
Message: <3D663B8E.8030809@free.fr>
Rafal 'Raf256' Maj wrote:
> Hello,
> width height
> line1
> line2
> line3
> where lineN is :
> where pixel is :
The problem might be to collect the information when it is available.
The traditional file writing code is usually given a line of pixel at a
time. Here, pixel being "traditional" pixel (rgba), not your pixel.
To collect your information, you will have to patch (heavily) the
rendering engine
so that not only it compute the color of the pixel, but also saves the
ray intersection... x,y,z: Evaluate_Ray(...),
Normal : You could have the classical 3 components vectors from the
intersection of the ray (IF there is an intersection, background does
not count), up to you to transform the vector,
distance is obviously the depth of the ray/intersection,
alpha is already part of the colour,
id : as long as you extend the object fields, the intersection will
provide you with the object pointer, the remaining is easy.
cpu_time : look at the histogramme code, calling the right function
before and after tracing each ray.
You have ONE BIG PROBLEM: Antialiasing!
You won't be able to perform it (what do you store if half the pixel is
from a sphere and the other half is a box or the background).
Date: 23 Aug 2002 09:56:28
Message: <Xns9273A183FE392raf256com@204.213.191.226>
Le Forgeron <jgr### [at] freefr> wrote in news:3D6### [at] freefr
> rendering engine
It realy looks not so easy, maybe I should start with basic r,g,b text
format.
With file/line is responsible for
- setting i.e. 'txt' and 'T' as output format
- creating output file
- adding pixel to buffer
- writing buffer/line to file
- closing it
Date: 24 Aug 2002 16:25:02
Message: <3D67EC21.C0C125E@free.fr>
Posting under my real name for once, I will revert to "Le Forgeron" right after.
(it's the week-end!)
> > rendering engine
> format.
+FT is already used for Uncompressed Targa 24bits
What about +FA instead (A: Ascii ?)
You do not have to update that code, unless you want more than RGBA in the buffer.
The file interface has only the knowledge of the concept of line.
Look in png_pov.* or targa.* for an example of the functions needed
(one open, one write a line, one read a line, one read full image, one close)
The buffer is there to delay the writing of x lines on the disk, instead
of making a disk access (or rather asking the system to do it) per lines.
Most useful when rendering small width, far less I/O, this keep the CPU working
on the useful things!)
> - closing it
Non Sine Numine
http://grimbert.cjb.net/
Etiquette is for those with no breeding;
fashion for those with no taste.
