POV-Ray : Newsgroups : povray.programming : the possibility of POSIX compliant threads ? Server Time
12 Jan 2026 03:36:37 EST (-0500)
  the possibility of POSIX compliant threads ? (Message 1 to 5 of 5)
Subject: the possibility of POSIX compliant threads ?
Date: 22 Apr 2003 01:06:01
Message: <Pine.GSO.4.53.0304220102400.3691@blastwave>
Dear POV fans :
    At great risk of being told to go back and read twelve threads ( no pun
 intended ) of discussion that are a year old, is there a possibility of
 a future POV-Ray release that has some multi-threading?  Possibly with a
 POSIX approach as opposed to something dependant upon Linux or Microsoft?
 Dennis
Subject: Re: the possibility of POSIX compliant threads ?
Date: 22 Apr 2003 03:31:10
Message: <3ea4efbe$1@news.povray.org>
In article <Pine.GSO.4.53.0304220102400.3691@blastwave> , Dennis Clarke
This question _really_ has been asked and _answered_ a ***million*** times
before.  So do what you said in the first line!
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Apr 2003 04:12:21
Message: <3ea4f965$1@news.povray.org>
In article <3ea4efbe$1@news.povray.org> , "Thorsten Froehlich"
I forgot, I could also say RTFM ;-)
"9.1.3.2 Can POV-Ray use multiple processors?"
<http://www.povray.org/documentation/view/309/>
    Thorsten
Date: 22 Apr 2003 15:34:50
Message: <Pine.GSO.4.53.0304221534110.5982@blastwave>
 I just knew that I'd get that !!   ;-)
    Dennis
Date: 23 Apr 2003 13:40:36
Message: <3ea6d013@news.povray.org>
Hmm... I have a crazy idea: If you need it, try and implement it.
Using UNIX, the easiest way is probably a post-fork after parsing.
Advantage: POVRay is not thread-save but as you use fork(), you get
cloned separate processes. Use pipes between the tasks and change
render.cpp (IMHO) so that each task only renders assigned image lines.
Use backwards pipes to have the image data sent back.
Time requirement: a day... or two.
Won't support radiosity and photons will be done by master only,
you may get trouble with continued tracing but if you just need more
speed quickly...
It you are creating an animation, renderin frames in parallel instead
of each frame in parallel is probably a better approach (less overhead).
(RendView (<- ask freshmeat or google) can do that using UNIX/Linux.)
Cheers,
Wolfgang
