POV-Ray : Newsgroups : povray.programming : OpenEXR 3.x issues - call to arms Server Time
22 Jan 2025 03:14:40 EST (-0500)
  OpenEXR 3.x issues - call to arms (Message 1 to 10 of 13)
Subject: OpenEXR 3.x issues - call to arms
Date: 2 Jun 2021 17:46:09
Message: <60b7fc21$1@news.povray.org>
Hi everyone,
anyone trying to compile POV-Ray with a modern version of OpenEXR - i.e.
3.0.0 or higher - will have noticed that we're having some snag there.
The reason behind this is that some time in the past, Industrial Light
and Magic (who had kicked off the OpenEXR thingumajig) had transferred
the whole shebang to the public, who picked up the ball and ran with it
like crazy.
Now, in March this year, this transfer has left its mark to the
structure of the project itself, leading to two major changes:
(1) The OpenEXR library, which used to be named `IlmImf` (for Intustrial
Light and Magic Image Format), has now officially been renamed to `OpenEXR`.
(2) An accompanying library, providing low-level mathematical stuff,
like a 16-bit floating-point data type, that used to go by the moniker
`IlmBase`, has been renamed to `Imath`.
This breaks all our builds, because those are not the libraries we are
looking for.
And someone needs to fix this.
I presume it's more a matter of diligence, that requires a bit of
understanding how an Automake-based build process works, but other than
that will hopefully not need deep insight into the bowels of POV-Ray
itself. And it also needs someone who can test any fixes before checking
them in - which I can't, because my Linux Fu is limited, and the Linux
machine I have convenient access to doesn't have OpenEXR 3 installed.
What I *think* needs to be done, is the following:
* Fix the Unix build process to do the right kind of version checking
and pulling-in of libraries (primarily relevant files:
`unix/configure.ac` and `unix/config/ax_check_openexr.m4`). The test for
the actual `IlmImf` library would have to be changed, to test for
`OpenEXR` instead if the version number detected is 3.0 or higher; also
in that case, a test for the `Imath` library would have to be performed,
which we currently don't have because it was effectively implicit when
OpenEXR was present.
* Fix whatever needs fixing to make sure our OpenEXR handling source
file (in v3.8 that would be `source/base/image/openexr.cpp` includes
whatever files need including. Maybe we need to include different files
if OpenEXR 3.x is installed. Maybe we just need to somehow adjust the
include paths. I'm not sure yet. I haven't dug that deep.
* Fix `source/base/povray.cpp` to pull in the proper version information
header files for the two libraries; again, you may need to change them,
or maybe you don't.
* (optional) While you're at it, you might also want to concoct a
mechanism by which to decide (depending on version number) whom to
credit as copyright holders, and what internet address to refer to.
Maybe also pull version information from the libraries via function
calls (as we do for other libs; but note the comment saying that such
function is unavailable in older versions). And maybe split up the
credit into two chunks, one for IlmImf/OpenEXR and the other for
IlmBase/Imath, as the libs are now fully separate projects.
* IMPORTANT: In all you do, make sure that the whole smash pretty much
behaves as before (except for maybe improvements to the copyright
notice) unless OpenEXR 3.0.0 or higher is indeed installed.
* If you're familiar with Git, submit your changes as a pull request to
the `master` branch in the repo.
The issues affect both v3.8 and v3.7, so you're not done yet:
* Do all of the above again for the `v3.7.0` branch, starting from
scratch. Whatever you did to fix v3.8, the same approach should also
work for v3.7, and the changes won't be much different. But the two
versions have grown too far apart to try and do anything that involves
merges. They'd bite you in the arse for trying. You figured out what
needed to be done, so you can do it again.
There. Now for the $0.000.000 question:
Any takers?
I know I could do it myself, but I'd prefer to spare my energy (which is
limited, as we've seen) and time for the work that still needs to be
done in POV-Ray's deep, deep gory bowels, where I dare not send anyone
else, lest they be devoured by the abominations that lurk there. You
know, the parser. The thing that software developers tell their children
bedtime stories about when they're refusing to go to sleep. The thing
that goes "bump" in the night `#if` you don't put an `#end` to it in
time. The thing that scares you shitless when you meet it at night in a
dark alleyway...
I think Lovecraft must have had premonitions of the POV-Ray parser code...
Subject: Re: OpenEXR 3.x issues - call to arms
Date: 3 Jun 2021 05:00:00
Message: <web.60b898d8cb27e48a79819d986cde94f1@news.povray.org>
hi,
> Hi everyone,
> like crazy.
> looking for.
my knowledge of the autotools is limited, but a quick look in 'unix/config'
shows that various macros test for the various libs, and 'ax_check_openexr.m4'
uses 'pkg-config' to do its thing.  looks like as long as 'pkg-config' is
up-to-date, only actual changed names of header files should impact.
regards, jr.
Date: 3 Jun 2021 09:35:00
Message: <web.60b8da01cb27e48a79819d986cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> my knowledge of the autotools is limited, ...
and so are my reading and comprehension, at times, evidently.
confused by your point (2) since 'Imath' is part of version 2.2.0 (and 1.7.1)
already.
regards, jr.
Date: 3 Jun 2021 19:43:39
Message: <60b9692b$1@news.povray.org>
Am 03.06.2021 um 15:32 schrieb jr:
> already.
I'm confused by it all, too. At any rate, the math portions are no
longer found (even when fixing the IlmImf->OpenEXR thing), and that has
to be fixed.
 From all I've read on the internet, one thing seems quite obvious:
Those math portions are no longer part of an accompanying library, but a
library that - at least at this point - constitutes an entirely
independent project. And I've found talk about it having been "renamed"
(whatever that means) from `IlmBase` to `Imath`.
It's an ideal job to be delegated: I'm just as confuzzled by it all as
anyone else.
Date: 3 Jun 2021 20:10:00
Message: <web.60b96ea1cb27e48a1f9dae3025979125@news.povray.org>
I am excellent at asking about or stating the obvious, so...
Presumably you have seen these (?):
https://github.com/AcademySoftwareFoundation/Imath/blob/master/docs/PortingGuide2-3.md
https://github.com/aforsythe/IlmBase
Date: 4 Jun 2021 15:15:16
Message: <60ba7bc4@news.povray.org>
Am 04.06.2021 um 02:06 schrieb Bald Eagle:
Nope.
That repo has been inactive since 2012.
As I mentioned, I haven't looked too deep into this yet. And there's
other stuff I have on my plate at the moment, which I can't delegate as
easily.
So if anyone could step up and take over this task - from digging up
info like the above, to actually implementing the necessary fixes - that
would be terrific.
Date: 6 Jun 2021 22:40:00
Message: <web.60bd8638cb27e48a6aa9bed67597fb06@news.povray.org>
> Nope.
> easily.
> would be terrific.
Hi clipka, I'll have a look at this. I hope that installing openexr 3 will go
alright and when that's done I can start telling povray to use then new openexr.
Ton.
Date: 7 Jun 2021 03:35:10
Message: <60bdcc2e$1@news.povray.org>
Am 07.06.2021 um 04:36 schrieb Ton:
Thanks, much appreciated!
Date: 15 Jun 2021 00:30:00
Message: <web.60c82c1fcb27e48a6aa9bed67597fb06@news.povray.org>
Persistence of Vision(tm) Ray Tracer Version 3.7.0.9.unofficial (g++ 9 @
x86_64-pc-linux-gnu)
  OpenEXR 2.3.0 and IlmBase 2.3.0, Copyright (c) 2002-2011 Industrial Light &
Magic.
  ldd unix/povray
        libIlmImf-2_3.so.24 => /lib/x86_64-linux-gnu/libIlmImf-2_3.so.24
(0x00007fd918405000)
        libHalf.so.24 => /lib/x86_64-linux-gnu/libHalf.so.24
(0x00007fd9183c0000)
        libIex-2_3.so.24 => /lib/x86_64-linux-gnu/libIex-2_3.so.24
(0x00007fd91839f000)
        libIlmThread-2_3.so.24 => /lib/x86_64-linux-gnu/libIlmThread-2_3.so.24
(0x00007fd917902000)
  OpenEXR 3.1.0-dev and Imath 3.1.0-dev, Copyright (c) Contributors to the
OpenEXR Project.
  ldd unix/povray
        libOpenEXR-3_1.so.29 => /usr/local/lib/libOpenEXR-3_1.so.29
(0x00007f7266ba5000)
        libIlmThread-3_1.so.29 => /usr/local/lib/../lib/libIlmThread-3_1.so.29
(0x00007f7266108000)
        libImath-3_1.so.29 => /usr/local/lib/../lib/libImath-3_1.so.29
(0x00007f72660b3000)
        libIex-3_1.so.29 => /usr/local/lib/../lib/libIex-3_1.so.29
(0x00007f7266032000)
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.11272893.unofficial
(g++ 9 @ x86_64-pc-linux-gnu)
  OpenEXR 2.3.0 and IlmBase, Copyright (c) 2002-2011 Industrial Light & Magic.
  ldd unix/povray
(0x00007fa2290b8000)
(0x00007fa229073000)
(0x00007fa229052000)
(0x00007fa2285e1000)
So that seems to be working. What is the best way forward with the changed
files, ax_check_openexr.m4, povray.cpp and openexr.cpp?
Date: 15 Jun 2021 08:51:41
Message: <60c8a25d$1@news.povray.org>
Am 15.06.2021 um 06:29 schrieb Ton:
Ideally, you'd set up a Git pull request for the `POV-Ray/povray`
repository, based on the `release/v3.7.0` branch (NOT `master`); and if
you feel like it, do the same based on the `release/v3.8.0` branch as
well (again NOT `master`), but I reckon it should be easy to port the
change over to v3.8 once it's in the Git repo.
If Git is not your sort of thing, please attach the files (complete - no
diffs please!) to a post over at `povray.binaries.programming`,
mentioning in the post what version you took the original files from.
Ideally someone else can take it from there and turn it into a pull
request or two - if not, I'll probably be able to find some time to take
it from there myself eventually.
