POV-Ray : Newsgroups : povray.programming : Binary meshes? Server Time
11 Jul 2026 00:18:33 EDT (-0400)
  Binary meshes? (Message 1 to 3 of 3)
Subject: Binary meshes?
Date: 14 Jun 2015 19:43:25
Message: <557e119d$1@news.povray.org>
Hi(gh)!
Still aiming at POVEarth/POVghanistan (and also high-quality renderings
of other Solar System bodies) - but currently, there is a bottleneck
when it comes to generating mesh2s from 16-bit (or whatever format)
heightfields!
The Japanese ASTER mission elevation tiles have a resolution of 3601 by
3601 measuring points (i. e. pixels in a heightfield generated from
these data) - but even with 16 GiB of RAM, I had to decrease the
resolution to 2600 by 2600, otherwise POV-Ray would crash.
Of course this is because POV-Ray generates full ASCII code rather than
(like with heightfields) binary data to internally represent the mesh2
object.
Have there ever been any attempts to write a patch to make binary meshes
feasible with POV-Ray?
See you in Khyberspace!
Yadgar
Subject: Re: Binary meshes?
Date: 15 Jun 2015 04:26:15
Message: <557e8c27$1@news.povray.org>
Hash: SHA256
Le 15/06/2015 01:43, Jörg 'Yadgar' Bleimann a écrit :
> Hi(gh)!
> renderings of other Solar System bodies) - but currently, there is
> a bottleneck when it comes to generating mesh2s from 16-bit (or
> whatever format) heightfields!
> 3601 by 3601 measuring points (i. e. pixels in a heightfield
> generated from these data) - but even with 16 GiB of RAM, I had to
> decrease the resolution to 2600 by 2600, otherwise POV-Ray would
> crash.
> than (like with heightfields) binary data to internally represent
> the mesh2 object.
> meshes feasible with POV-Ray?
> Yadgar
I lack half the full deck, maybe more:
What are you trying to achieve ?
Why is heightfield not suitable for that purpose ?
Checking the usage of gas-factory to fill a lighter : what would be
the final resolution of rendered images, in term of pixels, compared
to the resolution of input data ? (remember, a final pixel which hold
more than one input data is probably a waste, and holding thousand of
input pixels into a final single pixel is definitely a waste).
(aka: modelling the ball of the pen on a table in a garden in a
suburban area on an island in the middle of an archipelago is waste if
your final image is a map from a satellite view of the half planet
whose resolution would provide about 2 pixels for the city)
If you intend to dive into the view (for animation ?), the VRML
approach might be relevant: different aspects for different distances.
Also used in mipmap for textures in usual CG. You might need access to
the camera informations (either directly or via implied relations to
other values) to select the right body of modelling.
In Povray, mesh (including mesh2) is a collection of any triangles
anywhere in space. It allow great flexibility, including many-folds
terrain.
Whereas heightfield is single-fold horizontal terrain in a unit-cube,
in which the elevation of the points are known only for the one at an
exact grid position, and interpolated elsewhere. (and that
interpolation is not anisotropic : the grid is made of squares which
are cut in two triangles, always along the same axis: rotating the
image by 90° might give a different result)
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlV+jCYACgkQhKAm8mTpkW1RQAQAh3ortZEMBKXFktaarCT1mJZK
QaY919oEgknYKmz04eBDDMrrvWA7ek5a3SpZPsQHVxszMpCbT25Re+Krowd3AG+T
4kyhR1QxYu3eG0Pe0/xHni52+TOdN0JX6BEyy1Hu1+2mXoApW6k/GYjyN5XEMey2
oLCYF3aVcPR9HP/U1v0=
=TdXR
-----END PGP SIGNATURE-----
Date: 15 Jun 2015 09:05:54
Message: <557ecdb2$1@news.povray.org>
Hi(gh)!
My "heightfield" needs to follow Earth's curvature, so it has to be a mesh2!
Yadgar
