POV-Ray : Newsgroups : povray.programming : adding normal map from image capability? + other stuff Server Time
7 Dec 2025 19:55:26 EST (-0500)
  adding normal map from image capability? + other stuff (Message 1 to 2 of 2)
Subject: adding normal map from image capability? + other stuff
Date: 17 Nov 2014 13:30:12
Message: <546a3eb4$1@news.povray.org>
So, I've begun poking and prodding the POV-Ray code a bit lately, due to
my first foray into adding an on-screen indicator of which blocks are
actively rendering. (It works, but I'm not proud of how hacky it is for
some situations :) )
When I say normal map, I mean the RGB values are mapped to the XYZ of a
surface normal.
I've been looking at the bump map code and from what I can see, it
wouldn't be terribly hard to add this capability, controlled by a switch
on the bump_map image specification.
Are there any caveats that I am missing here... was there a technical
reason why this option wasn't implemented?
I'm thinking of adding something like rgb_normals to the bump_map as a
switch to change how the maps are handled.
The other thing I am investigating is putting together a client and
server architecture to allow for clustering, since the front and
back-end are now separate.
Probably with a "virtual" back-end on the front-end piece that would
pass to a coordinating server, and a virtual front-end to the server
piece that would pass the messages to the actual render engine (I think
I saw a few weeks someone here was doing something similar...)
Subject: Re: adding normal map from image capability? + other stuff
Date: 4 Dec 2014 04:00:04
Message: <54802294$1@news.povray.org>
Am 17.11.2014 19:30, schrieb Raiford, Michael:
> surface normal.
The simple reason why it hasn't been implemented yet is the lack of
those magical round tuits (as in, "I'll do it as soon as I get a round
tuit").
If you do embark on this, I'd recommend paying attention to object
and/or texture transformations (rotation, shearing and anisotropic
scaling, how are they supposed to affect the feature; and scaling in
general, when and how does it affect the "depth" of the effect), as well
as the interaction with the shape itself and/or other normal
perturbations; these things are where I reckon there might be some pitfalls.
If you do want to invest time into this, please contact Chris Cason, as
there are already some ideas and concepts floating around among the dev
team. (As a matter of fact the whole architectural overhaul for 3.7 was
originally geared towards this; only later did the issue of SMP come up
and get priority.)
