POV-Ray : Newsgroups : povray.programming : Porting away from VECTOR Server Time
28 Aug 2025 23:01:51 EDT (-0400)
  Porting away from VECTOR (Message 1 to 6 of 6)
Subject: Porting away from VECTOR
Date: 7 Mar 2014 21:29:53
Message: <531a80a1$1@news.povray.org>
I'm seeing a few things in the code that were deprecated, or were partially
replaced. For example, VECTOR is a plain array of three doubles, and there
are global C-like functions to work with them; but there's also a Vector3d
class. Is the intention to eventually port all uses of VECTOR to Vector3d?
(By the way, why does Vector3d have an array instead of just three members?)
Subject: Re: Porting away from VECTOR
Date: 8 Mar 2014 03:23:22
Message: <531ad37a$1@news.povray.org>
Le 08/03/2014 03:29, Nicolas Alvarez nous fit lire :
Just my guess: you cannot loop over members.
Date: 8 Mar 2014 13:30:50
Message: <531b61da@news.povray.org>
> partially replaced. For example, VECTOR is a plain array of three doubles,
> and there are global C-like functions to work with them; but there's also
> a Vector3d class. Is the intention to eventually port all uses of VECTOR
> to Vector3d?
Oh, I see clipka already did most of this porting in the 'refactor' git
branch :)
Date: 24 May 2014 13:53:45
Message: <5380dca9@news.povray.org>
Am 08.03.2014 09:23, schrieb Le_Forgeron:
More to the point, you can't index into members. Some internal code is
optimized in such a way that it needs to give one of the axes special
treatment (e.g. the axis closest to the direction in which a vector is
facing); in such cases, index variables are used for the axes rather
than hard-coded X=0, Y=1 and Z=2.
Date: 31 May 2014 23:02:24
Message: <538a97c0@news.povray.org>
>> doubles, and there are global C-like functions to work with them; but
>> there's also a Vector3d class. Is the intention to eventually port all
> branch :)
Are you planning to merge that back to master anytime soon?
Date: 15 Jun 2014 06:03:47
Message: <539d6f83$1@news.povray.org>
Am 01.06.2014 05:02, schrieb Nicolas Alvarez:
>> branch :)
Done that two days ago.
However, the 'refactor' branch is once again ahead already, and I can
now proudly announce that the last remaining references to VECTOR have
finally been squashed yesterday. (Well, kind of - it was actually some
hours after midnight, which leaves me kinda tired today, but that's
perfectly okay :)).
*Hooray!*
Next steps: Getting rid of UV_VECT, and eliminating COLOUR from the
back-end. Both will require major refactoring of the blend map handling,
which might turn out to be a tough nut to crack.
