POV-Ray : Newsgroups : povray.programming : Tool for converting ASCII text to POV-Ray string array Server Time
29 Aug 2025 06:38:07 EDT (-0400)
  Tool for converting ASCII text to POV-Ray string array (Message 1 to 1 of 1)
Subject: Tool for converting ASCII text to POV-Ray string array
Date: 18 Dec 2011 19:45:15
Message: <4eee891b@news.povray.org>
Hi(gh)!
I'm not sure whether I'm right in this group... but as it is not
possible to read in text line-wise from a file using #read (unless it is
specially formatted) I wrote a small C++ program which generates a
string array definition from any given ASCII text file... feel free to
use it!
// beginning of code
// ascii2povarray
// A utility to produce PoV-Ray string array definition code from any
ASCII text file
http://www.khyberspace.de)
#include <iostream>
#include <stdlib.h>
#include <fstream>
#include <string>
#include <vector>
using namespace std;
int main()
   ifstream ascii;
   string ascii_name;
   string line;
   unsigned int i;
   cout << "ASCII file name: ";
   cin >> ascii_name;
   ascii.open(ascii_name.c_str());
   if (!ascii)
     cerr << ascii_name << " cannot be opened!\n";
     exit (-1);
   char ch;
   vector<char> buffer;
   vector<string> code;
   unsigned int lines=0;
   while (ascii.get(ch))
     buffer.push_back(ch);
     if (ch == '\n')
       i=0;
       while (i<buffer.size()-1)
	// cout << "Hallo!" << endl;
	if (buffer.at(i)=='"')
	  line.append("\\\"");
	else
	  line.push_back(buffer.at(i));
	i++;
       code.push_back(line);
       buffer.clear();
       lines++;
     line.clear();
   ascii.close();
   ofstream povcode;
   string povcode_name;
   cout << "PoV-Ray script? ";
   cin >> povcode_name;
   povcode.open(povcode_name.c_str());
   if (!povcode)
     cerr << povcode_name << " cannot be opened!\n";
     exit (-1);
   povcode << "// INCLUDE FILE GENERATED WITH ASCII2POVARRAY" << endl;
   povcode << endl;
   povcode_name = povcode_name.erase(povcode_name.size()-4,
povcode_name.size());
   povcode << "#declare " << povcode_name << "_array = array[" << lines
<< "]" << endl;
   povcode << "{" << endl;
   for (unsigned int i=0; i<lines; i++)
     if (i==lines-1)
       povcode << "  \"" << code[i] << "\"" << endl;
     else
       povcode << "  \"" << code[i] << "\"," << endl;
   povcode << "};" << endl;
   return 0;
// end of code
See you in Khyberspace!
Yadgar
