POV-Ray : Newsgroups : povray.programming : Infinite coherent noise? Server Time
18 Mar 2026 09:35:28 EDT (-0400)
  Infinite coherent noise? (Message 1 to 8 of 8)
Subject: Infinite coherent noise?
Date: 21 Mar 2008 17:54:19
Message: <47e43c9b$1@news.povray.org>
I was wondering how POV is able to render coherent noise. Is it truly
infinite, or just nearly? I've never seen a repeat, but perhaps it
occurs just past the limit of observation.
I'm coding a simple demo of randomly generated topography, with the
ability to scroll around the landscape. The only noise generators I've
found reluctantly admit that the noise is "nearly infinite". I want an
absolutely infinite landscape, but I don't know if it's even possible.
Thanks~
Sam
Subject: Re: Infinite coherent noise?
Date: 21 Mar 2008 20:30:46
Message: <4G11TJC15F5HFwYn@econym.demon.co.uk>
Wasn't it stbenge who wrote:
>Hi,
It's actually worse than that. Any finite computing system has a maximum
number that its arithmetic system can represent. That places an absolute
limit on the size of any landscape that the computer can represent,
whether it involves random elements or not.
It's possible to create hardware random number generators that are truly
random, using quantum effects, but they'd be useless for generating
randomly generated topology because they wouldn't produce the same
random numbers when you re-render the scene.
Mike Williams
Gentleman of Leisure
Date: 23 Mar 2008 00:59:50
Message: <47e5f1d6@news.povray.org>
>> Hi,
Well, I just made a random landscape generator, and it's huge. I'm sure
it repeats eventually, but I haven't seen it happen.
I think we are still a ways off from seeing a commercial quantum
computer. Is there a way to achieve quantum effects apart from the
corresponding hardware?
Sam
Date: 23 Mar 2008 04:22:48
Message: <$xOEunBYFi5HFwq7@econym.demon.co.uk>
>>> Hi,
>>>truly  infinite, or just nearly? I've never seen a repeat, but
>>>perhaps it  occurs just past the limit of observation.
>>>I've  found reluctantly admit that the noise is "nearly infinite". I
>>>want an  absolutely infinite landscape, but I don't know if it's even >>>possible.
>>maximum  number that its arithmetic system can represent. That places
>>an absolute  limit on the size of any landscape that the computer can
>>represent,  whether it involves random elements or not.
Well that's what you'd expect with "nearly infinite". I wouldn't expect
to see any repetition in a landscape the size of the Earth.
>>truly  random, using quantum effects, but they'd be useless for
>>generating  randomly generated topology because they wouldn't produce
>>the same  random numbers when you re-render the scene.
Well you certainly can't write software that's sensitive to quantum
fluctuations on a deterministic digital computer, so you either need
some hardware that is sensitive to quantum fluctuations, or an external
feed of data that is generated by such hardware. Such external data
feeds include things like UK Premium Bond winning numbers and Lottery
winning numbers.
[UK Premium Bond numbers use the signal noise in transistors. Each
impact of the balls in a lottery machine doubles the angle of
reflection, so after a few hundred impacts a difference in initial
conditions at the quantum level would be amplified sufficiently to cause
a different ball to be selected.]
We're not talking "quantum computers" here. That's something completely
different.
Mike Williams
Date: 26 Mar 2008 14:23:18
Message: <Xns9A6DCF6062D01seed7@news.povray.org>
Could you use data from http://www.random.org?
ingo
Date: 26 Mar 2008 15:55:04
Message: <47eab828@news.povray.org>
I don't think so. I need determinate numbers, ones which I can expect to
see every time I punch in a new seed value.
Sam
Date: 26 Mar 2008 15:57:52
Message: <47eab8d0@news.povray.org>
>> sure it repeats eventually, but I haven't seen it happen.
Using what as a measuring stick? 1 pixel = 1 atom?
> winning numbers.
> different.
We're talking about chaos theory, yes? Nothing is truly random, rather
everything is a result of cause and effect. But try to predict it :)
Sam
Date: 27 Mar 2008 00:19:27
Message: <Byu7ufNV1y6HFw0i@econym.demon.co.uk>
>>completely  different.
We're talking real quantum effects (well at least I was) which most
current theories consider to be truly random. Chaos theory tells us that
we can build a machine that is so sensitive to initial conditions that
quantum events occurring in the atoms on the surface of the lottery
balls would cause different lottery outcomes.
Quantum computers work by causing a particle to be in a superposition of
many quantum states, each state representing a possible value that might
be the answer to some question, and somehow causing the superposition to
collapse to the state which solves the question that's being asked.
That's sort of going in the opposite direction from what we want.
Mike Williams
