POV-Ray : Newsgroups : povray.programming : Cross-compilation possible? Server Time
30 Apr 2026 12:43:49 EDT (-0400)
  Cross-compilation possible? (Message 1 to 10 of 11)
Subject: Cross-compilation possible?
Date: 27 Feb 2008 10:45:25
Message: <47c58595@news.povray.org>
Trying to cross-compile POV-Ray 3.6.1. Build platform: cygwin. I'll
leave you curious on what the host platform is.
As far as I know, the correct way to set it is using --host on the
configure script. That makes the configure script print this warning
(and then continue happily):
configure: WARNING: If you wanted to set the --build type, don't use
--host. If a cross compiler is detected then cross compile mode will be
used.
So I'm not sure if I'm really doing it right.
After configuring POV-Ray itself, it configures zlib. All works fine.
Then libpng, which also works fine. When it arrives to libjpeg, I get this:
checking for gcc... no
checking for cc... no
configure: error: no acceptable cc found in $PATH
Apparently it doesn't support --host. Maybe the fact that it was made
with autoconf 1.12 (and we're up to 2.61) has something to do :) Calling
it with 'CC=platform-gcc' as an argument makes it work correctly.
After libjpeg fails, POV-Ray's configure script *continues*, and starts
tiff's configure. That *also* fails, and POV-Ray's configure still says
it's all done and ready to run make! I think there should be checks for
sub-configures failing. Maybe starting the configure script of the next
library anyway (so the user can solve all problems at once before trying
again) but at the end giving a message that it's *not* all good and ready.
Second roadblock. Libtiff's problem is similar to libjpeg: it can't find
cc. Running it with --host, it says it's not even a valid option. it
doesn't even support giving it CC=platform-gcc as an argument, I have to
set it on the environment before running configure. I *just* noticed I
can also use --with-CC=platform-gcc. And I can pass the platform name as
an argument (without any switch), but that doesn't make it use the
correct CC name, so I don't know what it's useful for.
Now its configure script works fine. And third roadblock. libtiff's
makefile has a terrible habit of compiling tools (using the
cross-compiler!) and trying to run them; like mkversion, and another
tool to make a lookup table or something. Of course, this doesn't work:
"cannot execute binary file". I was able to manually create tiffvers.h,
but I won't be doing the same with the lookup table...
Fine, I get the idea. Libtiff won't cross-compile without a lot of hacking.
Feature request: let me disable it. It would make sense if I could
disable tiff support completely, giving an error when that file format
is used in an image_map or similar. Or what if I want a build without
*any* image support, for rendering RSOCPs on an embedded device?
Subject: Re: Cross-compilation possible?
Date: 27 Feb 2008 14:59:21
Message: <47c5c119$1@news.povray.org>
	Good idea  :-)
> with autoconf 1.12
	Yes, very likely.  The jpeg library is rather old anyway.
	This is a known problem that, IIRC, has been fixed for a 3.6.2 that
we unfortunately had no time to release yet  :-(
	The tiff library provided in POV's source distro is 3.6.1 IIRC, and
this one is rather ugly as far as configuration is concerned.  The latest
3.8.x series of libtiff are far better here.
	Yeah, I had this kind of nightmare to solve when trying to configure
libtiff from within POV's configuration.  So no surpises here  :-/
	I'd bet so.
	Then try the 3.7 unix sources that have been made available today  :-)
	(BTW, the external libs are no longer included in the 3.7 unix sources)
	- NC
Date: 27 Feb 2008 15:12:23
Message: <47c5c427$1@news.povray.org>
>     Good idea  :-)
Is that sarcastic? :) Technically, I don't even have access to the
platform I'm targeting, so there is no way I can do a native compilation.
libtiff.org says latest version is 3.6.1...
Great! I'll give that a try.
Can threading be disabled too? Preferably to a point where I don't need
to play around with Boost at all?
Uh, why am I asking at all... **downloads and checks by himself**
Date: 27 Feb 2008 15:46:43
Message: <47c5cc33$1@news.povray.org>
	Not at all, the install docs in the 3.6 source distro clearly mention
about cross-compiling -- i.e. that it would be nice someone tries it  :-)
	You have to dig into it a bit more.  Most Linux distro come with 3.8.2
which was released at least a year or two ago.
	No.
	- NC
Date: 27 Feb 2008 16:23:55
Message: <47c5d4eb@news.povray.org>
I couldn't figure out how to even start compiling the boost stuff. And
somebody who built it for the same platform I'm trying told me it was a
big pain to get it working. So I'll go back to trying with 3.6.1.
I found it. It uses autoconf, yay! Configure went perfectly in first
try, but make failed at this point:
http://www.pastebin.ca/921153
Apparently somebody has a precompiled libtiff I could use...
Nicolas
PS: yes, I realize that paste somewhat gives away the platform I'm
targeting.
Date: 27 Feb 2008 17:28:58
Message: <47c5e42a@news.povray.org>
I got *much* closer to success. All of POV-Ray, zlib, png, jpeg, fully
configured and compiled. Using a precompiled libtiff. On the very last
linking step:
ld: Undefined symbols:
setjmp(int*)
longjmp(int*, int)
___eprintf
collect2: ld returned 1 exit status
make[2]: *** [povray] Error 1
make[2]: Leaving directory `/home/Nicolas/povray-3.6.1/unix'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/Nicolas/povray-3.6.1'
make: *** [all] Error 2
Date: 27 Feb 2008 17:57:48
Message: <47c5eaec$1@news.povray.org>
> linking step:
> setjmp(int*)
> longjmp(int*, int)
> ___eprintf
Even closer! It was trying to link to C++ versions of setjmp and longjmp
(note there is an argument list and there is no leading underscore). I
had to add extern "C" in a few places. Now it's only complaining about
___eprintf.
Date: 27 Feb 2008 19:51:46
Message: <47c605a2@news.povray.org>
>> linking step:
>> setjmp(int*)
>> longjmp(int*, int)
>> ___eprintf
> ___eprintf.
Good news: complete success! I now have a POV-Ray binary that should run
on the iPhone or iPod touch.
Bad news: in my attempt to jailbreak my iPod touch to try my
compilation, I think I bricked it. Gah!
(when replying to this message, please post only to .programming if
replying the good news, and only to .off-topic if replying the bad news)
Date: 28 Feb 2008 05:06:21
Message: <47c6879d$1@news.povray.org>
	Did you try the --with-boost-src=DIR option of POV's configure?
I'd be quite interested to see whether it works for cross-compiling.
	- NC
Date: 28 Feb 2008 10:50:36
Message: <op.t68rl2gyc3xi7v@news.povray.org>
And lo on Thu, 28 Feb 2008 00:51:45 -0000, Nicolas Alvarez
<nic### [at] gmailisthebestcom> did spake, saying:
Damn you Microsoft for your propri... oh wait sorry; reflex action.
Ahem... well done to Apple for ensuring the quality of their fine, fine
products.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
