POV-Ray : Newsgroups : povray.programming : Some heightfield data read questions Server Time
11 Jun 2026 09:46:59 EDT (-0400)
  Some heightfield data read questions (Message 1 to 7 of 7)
Subject: Some heightfield data read questions
Date: 1 Mar 2007 04:33:48
Message: <45e69dfc$1@news.povray.org>
1. Why is GREY_SCALE3 interpretation being used on 16-bit color data
when it isn't on 24-bit data? (source/image.cpp, near line 540). This
winds up getting only effective five out of fifteen bits of elevation
precision.
2. When reading 16-bit grayscale TIFFs, shouldn't the Image->Image_Type
field be set to IS16GRAYIMAGE? GeoTIFF elev data can't be used as
heightfields correctly without this.
Ray Gardener
Daylon Graphics Ltd.
Subject: Re: Some heightfield data read questions
Date: 1 Mar 2007 05:21:33
Message: <45e6a92d$1@news.povray.org>
> precision.
I don't know how you come to the 'five out of fifteen bits' but the
special handling if 24 bit RGB images as 16 bit encoded in red and green
(see docs for how this works) was an ugly and inefficient hack
introduced when generic 16 bit formats where not yet common.  This hack
was not translated to 48 bit RGB - also since it would be rather
pointless since height values are stored with only 16 bit accuracy
internally anyway.
POV-Ray's support for Tiff images is limited to a very small subset due
to the design of libtiff that only provides higher level functions for
reading the most basic tiff formats.  I have implemented use of GDAL for
image reading some time ago (which would offer support for most Tiffs)
but it is unlikely to make it into an official release version due to
the optional support of closed formats in GDAL and resulting licensing
and support issues.  You have to convert such files into a format
supported by POV-Ray using external tools (Imagemagick, gdal_translate).
-- Christoph
Date: 1 Mar 2007 05:54:28
Message: <45e6b0e4$1@news.povray.org>
>> precision.
Elev encoding uses the red channel as the most signficant, but
GREY_SCALE3 only gives red a third of the "volume", so 16/3 ~= 5 bits.
The resulting renders in POV-Ray bear that out; the HF winds up terraced
to about 31 levels.
> but the
> internally anyway.
I don't personally have any issue with red+green interpretation, I'm
only saying, if that's how colors get converted to elevations, why not
do that consistently regardless of bit depth (except for 8 bits, where
it makes more sense to use palette indices).
Heightfields today have explicit file formats -- why not support some of
them? Then we could skip hacking altogether since images shouldn't be
coerced into persisting elevation data anyway. PNG and PNM already have
explicit 16-bit gray, as well as TIFF, and BT and USGS DEM are both
stable and public domain. I would just drop the whole color interp hack
altogether and insist on 8-bit gray, 16-bit gray, or true elev data.
There'd be a lot less confusion that way.
>> Image->Image_Type field be set to IS16GRAYIMAGE? GeoTIFF elev data
>> can't be used as heightfields correctly without this.
I can see that in some cases. I believe, though, libtiff is good about
providing the photometric interpretation value of a TIFF image being
read; if you want I can attempt a quick patch here and share the code.
You don't need to use libgeotiff or GDAL to read GeoTIFF in POV's case
-- libtiff itself will do -- since you're not reading any georef data.
Ray
Date: 1 Mar 2007 07:52:52
Message: <45e6cca4$1@news.povray.org>
> to about 31 levels.
Huh?
If you have a grayscale image stored in an RGB format (so R, G and B
identical for each pixel) i don't see how this handling reduces the data
to 31 levels.
As said the red+green interpretation is an old hack that only exists for
backwards compatibility.  And as also said there is absolutely no
practical use in having the same hack used for 48 bit images as well.
> them? [...]
POV-Ray supports PGM and PNG 16 bit grayscale images perfectly.  If you
like to implement support for additional formats you are welcome but a
bloated, proprietary or rarely used format will most likely not make it
into POV-Ray.
If you like to implement a broader Tiff support for POV-Ray using basic
libtiff functions you are welcome.  This is not a matter of a 'quick
patch' though.
-- Christoph
Date: 1 Mar 2007 13:51:39
Message: <45e720bb@news.povray.org>
Well, when TIFF support was added, the assumption was that libtiff would
provide all the support needed. But as TIFF is a pretty messy file format,
and libtiff does a rather poor job hiding all that TIFF complexity, support
in POV-Ray is a minimal set of features. This means grayscale isn't
supported currently.
I haven't checked 3.7 source, but maybe Chris Cason fixed that bit when
porting the old reading code. You may want to check the beta and see if it
does work. If not, and assuming it is correct that we can fix it with a
one-liner in the current 3.6 code, I am sure it can be added in 3.7 - just
file a bug report for the 3.7 beta then (and refer to this thread, too).
Either way, I cannot recommend using TIFF images unless you absolutely have
to. I would recommend PNG images, which are much better supported in POV-Ray
 due to libpng being usable on a favorable level of abstraction that doesn't
force us to worry about format oddities too much :-)
	Thorsten
Date: 1 Mar 2007 17:53:25
Message: <45e75965@news.povray.org>
>> bits. The resulting renders in POV-Ray bear that out; the HF winds
>> up terraced to about 31 levels.
> Huh?
> data to 31 levels.
It's when the channels are used in red+green encoding; certainly a
grayscale image would work but it would only enjoy up to eight bits of
precision, which defeats the purpose of using 16 bits. For 16-bit r+g
though that only gives 10 bits so r+g+b would be preferred.
Maybe the consistency should work the other way... apply GREY_SCALE3 to
24-bit RGB as well, and if people want elev precision beyond eight bits,
they need to use PNG/PGM. I wanted to offer a freedom of choice in terms
of formats because POV-Ray lists several of them when reading HF files,
but limiting Lev's POV export to PNG/PGM is probably more warranted --
doesn't hurt the functionality and avoids potential confusion.
Ray
Date: 2 Mar 2007 01:25:03
Message: <es8frc$h6m$1@chho.imagico.de>
Well - if you have a program generating a red channel only RGB image i
can't help.  Note a red *and green* encoded image in 48 bit would not
work at all (since the green values would mess it).  Apart from that
things are clear:
Grayscale image in 48 bit RGB -> 16 bit accuracy
Grayscale image in 24 bit RGB -> 8 bit accuracy
Red+Green encoded image in 24 bit RGB -> 16 bit accuracy
and of course true grayscale images always in native accuracy.
Note you can use a red+green 48 bit RGB image in POV-Ray by manually
combining the values in functions and thereby even achieve > 16 bit
accuracy but this won't help for heightfields.
As said two times already this is not done for *backwards compatibility*.
It also would avoid users to use a pointlessly bloated format using 1.5x
the required space for storing the values...
Views of the Earth: http://earth.imagico.de/
Images, include files, tutorials: http://www.imagico.de/
