POV-Ray : Newsgroups : povray.programming : tutorials: adding new spline type, adding new keywords Server Time
15 May 2026 20:13:42 EDT (-0400)
  tutorials: adding new spline type, adding new keywords (Message 1 to 7 of 7)
Subject: tutorials: adding new spline type, adding new keywords
Date: 9 Aug 2002 14:12:36
Message: <4318lu4lp102qd1dnn1curjqvicceb78td@4ax.com>
My latest patch can be considered as tutorial about adding new types of spline
to POV sources and about adding new tokens recognition. It is available at:
http://abx.art.pl/pov/patches/sorspline.php
ABX
Subject: Re: tutorials: adding new spline type, adding new keywords
Date: 9 Aug 2002 20:47:52
Message: <1720078.4mrfNVtrGG@3-e.net>
> spline to POV sources and about adding new tokens recognition. It is
> available at:
> ABX
Thanks for that, it gave me a useful insight into POV's internals.
It also made me wonder if in some future version of POV the parser could be
data driven from an XML file so that it was extensible without having to
recompile. The XML file would supply the token information and a reference
to a loadable object or plug-in.
I know this can't work for all things you may need to patch, but for adding
new geometry, functions and patterns etc. it should work.
Such a method would let everyone try out new ideas immediately so that they
were well tested and could be more rapidly incorporated into the POV source
code (for speed?) at the next major release.
Your connection failed because: short leg on process table
Date: 9 Aug 2002 20:56:21
Message: <chrishuff-BC6665.19463509082002@netplex.aussie.org>
In article <172### [at] 3-enet>, Daniel Matthews <dan#@3-e.net>
This has the same problem as any other plug-in idea, it is platform
dependant. You can't dynamically load code in a platform independant
way, and the plugins would only work for the platform they are compiled
on. If you could, you wouldn't need the XML representation of the syntax.
http://tag.povray.org/
Date: 10 Aug 2002 20:52:25
Message: <1193675.vgbHYTHmde@3-e.net>
>> be data driven from an XML file so that it was extensible without having
>> to recompile. The XML file would supply the token information and a
>> reference to a loadable object or plug-in.
Oh, I see, but how does some Linux multimedia software such as mplayer uses
Windows codecs to decode and encode Video and Audio files?
Your connection failed because: Mail server hit by UniSpammer.
Date: 10 Aug 2002 21:22:05
Message: <3d55bc3d@news.povray.org>
  Emulation. It uses a piece if WINE in order to do it.
Date: 10 Aug 2002 22:16:14
Message: <chrishuff-9FDF1B.21042610082002@netplex.aussie.org>
In article <119### [at] 3-enet>, Daniel Matthews <dan#@3-e.net>
The processor and machine are the same, so they just have to reimplement
some stuff to run the code under Linux. It is impossible on Linux
distributions for machines that can't run Windows, such as LinuxPPC
(making an emulator for an entirely different architecture is not a
simple task, and the result will be pretty slow). For POV, you would
have to write an emulator for every supported platform to emulate every
other supported platform, and that still doesn't work for plugins that
use OS specific API's.
And finally, that is Linux software running under Linux. You can't just
compile it under Mac or Windows. There is no cross-platform way to
dynamically load plugins like that, each platform would have to
implement its own version.
Date: 1 Sep 2002 12:00:08
Message: <web.3d72394b4abd409e653282a30@news.povray.org>
>In article <119### [at] 3-enet>, Daniel Matthews <dan#[at]3-e.net>
But once its done, then its done, if fact its already been done as dlcompat,
I think the licence is MIT/BSD.
It seems a shame to deny povray users useful extra functionality just to
avoid a little bit of one off effort. I've actually got the source for a
dlfcn 'port' for BeOS open now, under a MIT/BSD licence, its under 300
lines of well spaced out, well commented code. The fink project has
dlcomplat for OSX, it can also be found for open darwin, I would be
suprised in you couldn't find it somewhere under its orginal licence.
That just leaves the thorny subject of compiling the plugins for the
appropriate plaforms, which is only  a problem for closed source plugins,
for open source ones its just requires one person who wants the plugin or
that plaform to create a binary distribution.
Dave
