POV-Ray : Newsgroups : povray.programming : Program to reassemble tiles into a full image Server Time
29 Aug 2025 17:59:20 EDT (-0400)
  Program to reassemble tiles into a full image (Message 1 to 6 of 6)
Subject: Program to reassemble tiles into a full image
Date: 7 Aug 2004 20:31:30
Message: <41157462$1@news.povray.org>
Hey fellow POV-Ray hackers,
     Do you know of a program that will run under linux and recombine a
set of image tiles into one image? Preferably PNG 24 and 48-bit would be
supported. Also, will it cope with the tile images output by POV-Ray
(which have their dimensions incorrectly specified to allow continued
tracing) ?
Thanks,
George
George Pantazopoulos
http://www.gammaburst.net
Subject: Re: Program to reassemble tiles into a full image
Date: 8 Aug 2004 08:35:09
Message: <41161dfd$1@news.povray.org>
> tracing) ?
Have a look at ImageMagick:
http://www.imagemagick.org/
Tor Olav
http://subcube.net
http://subcube.com
Date: 8 Aug 2004 08:46:18
Message: <4116209a$1@news.povray.org>
>> be supported. Also, will it cope with the tile images output by
>> POV-Ray (which have their dimensions incorrectly specified to allow
>> continued tracing) ?
The last of these examples for "montage";
http://www.imagemagick.org/www/montage.html#mont-exam
- seems to be somewhat similar to your problem.
I don't know much about ImageMagick, so I'm not
sure if it can help you with your problem.
Tor Olav
http://subcube.net
http://subcube.com
Date: 8 Aug 2004 08:55:02
Message: <cf57i7$9k5$1@chho.imagico.de>
> tracing) ?
POV-Anywhere comes with a command line tool to assemble partial renders
in ppm format to a large image.  It supports both 24 bit and 48 bit
images but it is not very fault tolerant, the tiles should have the
correct size without gaps and overlaps.
http://www.tu-bs.de/%7Ey0013390/povany/index.html
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 8 Aug 2004 22:18:58
Message: <4116df12$1@news.povray.org>
Thanks for the link!
G
Date: 8 Aug 2004 22:19:41
Message: <4116df3d$1@news.povray.org>
> Christoph
Hi Christoph,
    Your povtile program works wonderfully. Thanks for making it!
George
