POV-Ray : Newsgroups : povray.programming : libpng Security Vulnerabilities Server Time
29 Aug 2025 17:59:20 EDT (-0400)
  libpng Security Vulnerabilities (Message 1 to 5 of 5)
Subject: libpng Security Vulnerabilities
Date: 5 Aug 2004 09:32:30
Message: <411236ee$1@news.povray.org>
Read this for more details:
http://www.us-cert.gov/cas/techalerts/TA04-217A.html
POV-Ray 3.6 uses libpng 1.2.5, a vulnerable version.  This means a scene
file using a PNG image map could potentially contain a malicious
payload.
Given the vast number of applications that use libpng, this is scary...
-Ryan
Subject: Re: libpng Security Vulnerabilities
Date: 5 Aug 2004 10:35:02
Message: <cetgc0$8po$1@chho.imagico.de>
Ryan Lamansky wrote:
> This means a scene file using a PNG image map could potentially contain
a malicious payload.
You should use correct formulations, this is nonsense as you wrote it.
A broken PNG image can cause security problems when you use it in
POV-Ray as an image map.
The whole thing isn't new, there have been similar problems with other
support libraries before.  I really don't understand why people make so
much fuzz about it.  If you had asked me a week ago to bet $1000 on
libpng containing vulnerabilities or not the answer would have been
completely clear.
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 5 Aug 2004 11:25:33
Message: <4112516d$1@news.povray.org>
This isn't a slam against POV-Ray, or anything like that.  I'm just in
shock from the thought that an image file could hack me.
This vulnerability is relatively minor for POV-Ray, since so much user
involvement is needed.  Things are a little different for web
browsers...
-Ryan
Date: 5 Aug 2004 11:55:07
Message: <4112585b@news.povray.org>
In article <cetgc0$8po$1@chho.imagico.de> , Christoph Hormann
> completely clear.
It still is today.  I would still bet $1000 that more will be found in the
future.  I would actually hold that for absolutely every non-trivial
software out there.
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Aug 2004 12:44:31
Message: <411263ef@news.povray.org>
Ryan Lamansky <Spa### [at] kardaxcom> wrote:
> I'm just in shock from the thought that an image file could hack me.
  It's much easier to give you a trojan as an SDL script than with
a png.
