POV-Ray : Newsgroups : povray.programming : Parametric object fix Server Time
28 Sep 2024 20:16:35 EDT (-0400)
  Parametric object fix (Message 1 to 3 of 3)
Subject: Parametric object fix
Date: 3 Jul 2004 14:38:50
Message: <40e6fd38@news.povray.org>
As already mentioned in the previous thread, I have come up with a
"solution" for the parametric object bug (crash) as reported by me
(on 20 Jun 2003 21:49:03 in p.programming)
There are two problems:
(1) When accuracy is made too small, an internal fixed-size array overflows.
(2) Unless using no_shadow, the parametric object may be completely black.
This (completely black object) can be seen e.g. using:
#include "functions.inc"
global_settings { assumed_gamma 2.2 }
light_source { <-0.4,0.2,-0.3>*20, rgb <2,2,2>/2 }
light_source { <0.2,1,-0.8>*20, rgb <2,2,2>/1.7 }
#declare m=3;
parametric {
Let's come to the black object (2) first:
Somebody (I do not know who) supposed a patch for this which was
as follows (IMO):
We need DEPTH_TOLERANCE again...
...and insert the two lines indicated with "+" below:
---------------<fpmetric.cpp around line 220>------------------
This will make the above code render a nice green parametric object.
I must admit that I do not completely understand why this works and
it was not me who suggested it. I recall that some of my tests made
the object have no self-shadow, so here comes a modified test scene which
was used to verify that shadow and self-shadow work correctly for
accuracies 0.01 and 1e-9: (NOTE! This needs the patch for (1) applied,
see below.)
I do not know if we should apply this. Somebody with more clue about
the code should comment on that. This change may have side effects
which I am not aware of. But it seems, this solution is at least better
than the current one.
light_source { <0.2,0.3,-0.3>*20*5, rgb <2,2,2>/1.7 }
#declare m=3;
parametric {
plane { y,-15 pigment { rgb x }}
Solution for (1)
This is what I verified to work with a test scene (the one above with
different accuracy values in range 1e-3 to <1e-10):
First of all, we should get rid of the fixed array sizes 32 for internal
solver sectors:
Around line 120, replacing
-static DBL Intervals_Low[2][32], Intervals_Hi[2][32]; // GLOBAL VARIABLE
-static int SectorNum[32]; // GLOBAL VARIABLE
+static DBL Intervals_Low[2][SECT_DIM], Intervals_Hi[2][SECT_DIM];
+static int SectorNum[SECT_DIM]; // GLOBAL VARIABLE
should do the trick. This will use fixed-size SECT_DIM=48. It showed, that
using more does not make sense given double precision. Actually, the old
value 32 would also suffice for most tasks but no disortion appears with
accuracies which need 48 or even 64 sectors. (One could use 64 to be on
an even safer side.)
Around line 408, the solver bailout test reads:
The best thing we can probably do is to also bail out if the number
of available sectors is insufficient. This means that the accuracy will
no longer be guaranteed but OTOH dynamically increasing the
number of sectors without any limit may IMHO trap us in an endless
(or neraly endless) loop when fed with pathological functions.
Hence, I suggest to do the following:
I verified that this works as expected with the test scene with different
accuracy settings and with different values for SECT_DIM (16..64).
Somebody with more clue about the code could please comment on
that. At least my solution should be better than the current behaviour.
Furthermore, there is an uneccessary test:
Around line 350:
There is IMO no way how SectorNum could get zero or negative. The second
test can be left away for the Z component (it is actually BOT present for X
and Y).
Hence,
should work just fine. At least no problem showed up in my tests.
Wolfgang
Subject: Re: Parametric object fix
Date: 6 Jul 2004 07:01:21
Message: <40ea8681@news.povray.org>
"Wolfgang Wieser" ha scritto ...
> #declare m=3;
> parametric {
> function { u*sin(v) }
> function { 15*sqrt(pow(sin(m*v)*sin(u/2)/3,2)+
> pow(cos(m*v)*m/u*sin(u/2)/3,2)) }
> function { u*cos(v) }
> <0.001,0>, <15,2*pi>
> contained_by { sphere { 0, 15 } }
> precompute 12 x,y,z
> accuracy 0.00001
> pigment { rgb y }
> camera { location <0,0.6,-1>*8.3*3 up y look_at <0,0,0> }
> as follows (IMO):
I suggested it
> Depth1 = 0;
> + if (Depth1 < DEPTH_TOLERANCE)
> + Depth1 = DEPTH_TOLERANCE;
> if ((Depth1 += 4 * Par->accuracy) > Depth2)
> return false;
> Intervals_Low[INDEX_U][0] = Par->umin;
> see below.)
I do agree, IMO it is better than the current.
My (short) comment on why the fix works:
The problem is that the surface is getting self shadowed for accuracy
problems. The black color is the result of the surface being shadowed
by itself.
The intersections between a ray and the parametric surface are not
computed exactly, the algorithm would eventually converge to the solution,
but you need to stop it at some point. So you obtain an approximated
intersection, that's likely NOT on the surface, it is near, but either
in front or behind the surface.
Shooting a ray from the approximated (behind) intersection point to the
light, it will find the same surface at a small distance from the start.
So the sense of the fix is to reduce the range in which to search a valid
intersection. It is something that is done for nearly every primitive in
POVray.
HTH
Massimo
Date: 10 Jul 2004 04:04:20
Message: <40efa304@news.povray.org>
>> as follows (IMO):
> I suggested it
I just added a note (and your explanation) to the sources so that I know
next time... :)
Wolfgang
