POV-Ray : Newsgroups : povray.programming : Implementing new light source function Server Time
15 May 2026 14:33:21 EDT (-0400)
  Implementing new light source function (Message 1 to 5 of 5)
Subject: Implementing new light source function
Date: 2 Mar 2004 11:47:05
Message: <4044ba89@news.povray.org>
Do you think is possible to implement a new function for a light source,
with rays function of solid angle (seeIES standard). I different words,
having the possibility of controlling the energy of rays in relation with
horizontal and vertical angle. It would be very usefull for modelling
Thank you all.
Subject: Re: Implementing new light source function
Date: 2 Mar 2004 15:31:55
Message: <4044ef3b$1@news.povray.org>
This could probably be done in SDL with a sphere with a filtering pigment
around a normal light source, unless I misunderstand.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 2 Mar 2004 20:11:19
Message: <404530b7$1@news.povray.org>
If you are working with isosurfaces (and if you don't care about
shadows), then you can calculate how much a light source illuminates
a point on the surface by using functions in SDL. (I.e. you don't
need to patch POV-Ray to do this.)
I once used such a technique to make a few simple images.
Some of them can be found in this thread:
http://news.povray.org/povray.binaries.images/thread/%3CXns93A4378303A9Ftorolavkhotmailcom%40204.213.191.226%3E/
or http://tinyurl.com/ytkvh
It should also be possible to do something similar with meshes
made up of (small) triangles.
Tor Olav
Date: 2 Mar 2004 20:35:18
Message: <40453656$1@news.povray.org>
>> purpose.
I forgot to mention that you would have to make a function that
describes the energy distribution at different angles around (or
relative to ?) the light source.
The source code for the mentioned images can be found here.
http://news.povray.org/povray.text.scene-files/thread/%3CXns93A54E262AE2torolavkhotmailcom%40204.213.191.226%3E/
or http://tinyurl.com/2dbua
(It might give you some hints about how to start attacking this
problem.)
Tor Olav
Date: 3 Mar 2004 11:54:51
Message: <Xns94A1B63BA859Dseed7@news.povray.org>
> pigment around a normal light source, unless I misunderstand.
The hard part would probably be to convert luminance file to functions.
Ian Ashdown made a parser available for parsing IESNA LM-63 and similar
files, maybe that could be a start.
Also if I remember well, there was somebody who patched povray in a way
that it could work these IES files, but the code was never published.
Can't find the discussion, it was about a year (or more) ago.
I would realy welcom a POV-Ray feature that could read and deal with such
files directly. Many manufacturers of lighting systems make these data
available.
Ingo
