POV-Ray : Newsgroups : povray.programming : Question about radial pattern Server Time
1 Apr 2026 23:51:42 EDT (-0400)
  Question about radial pattern (Message 1 to 6 of 6)
Subject: Question about radial pattern
Date: 25 Feb 2004 07:29:14
Message: <403c951a@news.povray.org>
I just decided to implement some new pattern and stepped over
the following in pattern.cpp:
* FUNCTION
*   radial_pattern
* RETURNS
*   DBL value in the range 0.0 to 1.0
static DBL radial_pattern (VECTOR EPoint)
  register DBL value;
  if ((fabs(EPoint[X])<0.001) && (fabs(EPoint[Z])<0.001))
  {  value = 0.25;  }
  else
  {  value = 0.25 + (atan2(EPoint[X],EPoint[Z]) + M_PI) / TWO_M_PI;  }
  return(value);
Since atan2() will return values in range -Pi..Pi, the return value
of the pattern will be in range 0.25 .. 0.25+2*Pi and not in range
0..1 as stated in the description of the function.
Wolfgang
Subject: Re: Question about radial pattern
Date: 25 Feb 2004 10:56:35
Message: <403cc5b0@news.povray.org>
Grbml... I mean 0.25 .. 1.25, i.e. 0.25 + 2*Pi/(2*Pi). -Sigh-
Wolfgang
Date: 25 Feb 2004 13:21:41
Message: <cjameshuff-60F261.13222825022004@news.povray.org>
In article <403c951a@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
>   register DBL value;
>   {  value = 0.25;  }
>   else
>   return(value);
Note that the code adds pi to atan2() and divides the result by 2*pi
before adding the 0.25. So the range of the function is [0.25, 1.25]...I
don't know why. It gets wrapped to [0, 1] later anyway...maybe it was
done to make the pattern start at +x. Seems unnecessary to me, but
changing it would affect every scene that uses radial. Though you could
make it dependent on version.
http://tag.povray.org/
Date: 25 Feb 2004 14:21:07
Message: <403cf5a2@news.povray.org>
>>   register DBL value;
>>   {  value = 0.25;  }
>>   else
>>   return(value);
[ Note that I corrected this mistake of mine about 3.5 hours before your
post :) ]
> I don't know why. It gets wrapped to [0, 1] later anyway...maybe it was
Well, but instead of adding 0.25 one could use atan2(z,-x) instead of
atan2(x,z). Why not write:
value = (atan2(EPoint[Z],-EPoint[X]) + M_PI) / TWO_M_PI;
Now, the values are back in range 0..1 and it behaves exactly like
the current one (after being wrapped to 0..1).
Wolfgang
Date: 25 Feb 2004 14:51:33
Message: <403cfcc5@news.povray.org>
In article <403cf5a2@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
> post :) ]
And note that your clock is one hour behind the real-world :-)
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Feb 2004 16:37:25
Message: <403d1594@news.povray.org>
>> post :) ]
Oh, yeah... correct. Just installed debian "sid" yesterday.
The issue is "hardware clock stores UTC" vs "hwclock stores local time".
I noticed that yesterday when going to bed 1 hour too late :p
...and forgot to adjust it today.
Wolfgang
