POV-Ray : Newsgroups : povray.programming : Two possible minor bugs in pvengine.c Server Time
28 Sep 2024 22:19:39 EDT (-0400)
  Two possible minor bugs in pvengine.c (Message 1 to 2 of 2)
Subject: Two possible minor bugs in pvengine.c
Date: 4 Feb 2004 02:55:02
Message: <4020a556$1@news.povray.org>
If found next possible (very minor) bugs in pvengine.c
Line 665:
if (ClockTimeTotal >= 1000)
Should probably be:
if (ClockTimeTotal >= CLOCKS_PER_SEC)
This makes it more consistent on different platforms. And if CLOCKS_PER_SEC
is defined very low, it might get a while to see the actual PPS reading :)
Line 4294:
status_printf (StatusPPS, PPS_String (pixels, ClockTimeTotal / 1000)) ;
Should probably be:
CLOCKS_PER_SEC)) ;
These are, of course, very minor and affect barely anything. On non-Windows
platforms (or non Visual C++ compilers?) the PPS reading might be wrong
when rendering is paused, if CLOCKS_PER_SEC is not 1000. Including the fix
to 3.6 would be probably very safe - if needed to.
Severi Salminen
Subject: Re: Two possible minor bugs in pvengine.c
Date: 5 Feb 2004 04:49:02
Message: <4022118e@news.povray.org>
"Severi Salminen" <sev### [at] NOT_THISsibafi> wrote in message
news:4020a556$1@news.povray.org...
> Should probably be:
> CLOCKS_PER_SEC)) ;
you are correct; I am inconsistent in my use of the above define (in some places I use
1000 and in others I use CLOCKS_PER_SEC).
I'll ensure it's used in all places.
-- Chris
