POV-Ray : Newsgroups : povray.programming : enum { SOMETHING = 'Thing' } ? Server Time
15 May 2026 14:34:00 EDT (-0400)
  enum { SOMETHING = 'Thing' } ? (Message 1 to 10 of 13)
Subject: enum { SOMETHING = 'Thing' } ?
Date: 31 Jan 2004 15:42:33
Message: <401c1339$1@news.povray.org>
This syntax is new to me:
/* POV-Ray Message Classes */
enum
 kPOVMsgClass_RenderControl   = 'Ctrl',
 kPOVMsgClass_RenderOutput   = 'Outp',
 kPOVMsgClass_IniOptions    = 'IniO',
 kPOVMsgClass_Miscellaneous   = 'Misc'
}; //           How does this work ? --^^^^^
'Ctrl' is quite a bit different from what I'm used to using for enumeration,
and also looks a bit like a four-byte char?
Subject: Re: enum { SOMETHING = 'Thing' } ?
Date: 31 Jan 2004 16:16:04
Message: <muhte1-ch6.ln1@triton.imagico.de>
> enum
These are multicharacter character constants but they do not need to
bother you.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 2 Feb 2004 05:07:56
Message: <t58s1015437i6sh8q0jv9m16sm6eomafna@4ax.com>
On Sat, 31 Jan 2004 12:42:19 -0800, "AngleWyrm"
'Ctrl' is alternative notation for 32-bit integers here.
ABX
Date: 2 Feb 2004 05:52:23
Message: <401e2be7@news.povray.org>
  'Ctrl' is the value 1131704940.
  (If you can't deduce why, I can explain that as well.)
Date: 5 Feb 2004 02:14:21
Message: <4021ed4d$1@news.povray.org>
news:401e2be7@news.povray.org...
'C'<<32|'t'<<16|'r'<<8|'l'
What I can't deduce is where/how the value of the enum is used.
I've seen some lines using if(cur->handledclass == hclass) type statements,
but this is just normal enum handling.
Date: 5 Feb 2004 02:28:51
Message: <4021f0b3$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:t58s1015437i6sh8q0jv9m16sm6eomafna@4ax.com...
enumeration,
So this would be saying the same thing sleightly differently:
#define CTRL 1131704940
enum { kPOVMsgClass_RenderControl   = CTRL }
Is this numerical encoding used as an error catching mechanism during code
construction? I haven't been able to find further references to 'Ctrl'
outside the enum declaration.
Date: 5 Feb 2004 02:47:31
Message: <60t320p8r7lpgepjg2nplk9ptkkgskioq9@4ax.com>
On Wed, 4 Feb 2004 23:21:28 -0800, "AngleWyrm" <no_### [at] hotmailcom>
Are you looking references to 'Ctrl' or to kPOVMsgClass_RenderControl?
ABX
Date: 5 Feb 2004 06:12:35
Message: <40222523@news.povray.org>
news:60t320p8r7lpgepjg2nplk9ptkkgskioq9@4ax.com...
code
'Ctrl'
If the enums were given specific values, it was my guess that at some point
in the program a comparison to, or usage of those specific values would take
place. Makes sense?
Thus I surmized that there must be more than one occurance of the term 'Ctl'
within the source files, so I went looking for this. I only found the one
occurance, and this got me wondering if it was an exception to a norm. Hey
maybe the rest of them or even just some of them are used in some
comparison.
So I did a grep search on '\(....\)' to find all single quoted four-letter
blocks. The only code (besides comments) that came back were the
enumerations themselves. (www.textpad.com, nice notepad replacement)
Thus far, it seems that my guess may be in error; perhaps those values
aren't used anywhere else?
Date: 5 Feb 2004 07:02:58
Message: <402230f2$1@news.povray.org>
Some possible reasons:
* It may have applied to old code that is no longer a part of the program
* It may have applied to an old plan that was never implemented
* It may have been a method of creating a 'sparse' enum set, to avoid
accidentally refererencing with the wrong kind--But there's a better ways to
catch that mishap:
enum animals {CAT, DOG, MOUSE};
enum colors {RED,GREEN,BLUE};
void MyAnimalFunc( animals eInput ){}; // enum type specified
int main(void)
  MyAnimalFunc( CAT ); // works fine
  MyAnimalFunc( RED ); // compiler gets it: cannot convert 'colors' to
'animals'
* It might apply to tools/utilities that reside outside the program
* I've overlooked something totally obvious, and should go get another cup
of coffee
Date: 5 Feb 2004 07:54:07
Message: <40223cef$1@news.povray.org>
In article <40222523@news.povray.org> , "AngleWyrm"
> place. Makes sense?
No, nobody would define enums and then not use them.  Enums are given
"names" because those mean more to a human when debugging.  Otherwise you
would always have to manually count which value you are currently dealing
with, which is insane if you are dealing with more than just a handful of
value.
    Thorsten
e-mail: tho### [at] trfde
